Local Time 11:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Loops
vk4tec
Posted: 06:10pm 10 Jul 2013
Hello
When I am dealing with GPS sometimes the data can not be there. Missing serial.
In that the GPS has gone away. - Failure mode
Can you only run one settick loop ?
I would like to have an independant loop that changes an LED based on the GPS stream is active or not.
Comments ?
As opposed to an LED on / off in the "wait for GPS data" loop.
- Andrew-
Andrew Rich VK4TEC
www.tech-software.net
cwilt
Posted: 06:41pm 10 Jul 2013
You could base it off of the validation field in GPRMC sentence. Its the 2nd data field in the sentence. Use a global variable that resets to 0 when anything but an A is there. Have your settick loop check that variable.
That validation field is in other nema sentences too.
