Local Time 12:12 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic 44b7 playmod/file bug
psergiu
Posted: 06:29am 10 Jul 2013
I just installed MMBasic 4.4 beta 7 on my Duinomite Mini to try the playmod command.
After i tried copying a .mod file that was too large to a: playmod fails with the "Only one file can be opened" error.
Steps to reproduce:
copy to SD card 2 mod files whose sizes together are larger that the available space on A:
COPY "B:FILE1.MOD" TO "A:"
PLAYMOD "A:FILE1.MOD"
- file plays okay
PLAYMOD STOP
COPY "B:FILE2.MOD" TO "A:"
- you get the error "No space on media"
KILL "A:FILE2.MOD"
- you get the error "Only one internal flash file can be open at a time". You need to reset in order to be able to use playmod again.
It seems that the failed copy operation is leaving the file descriptor open or something similar.
Thanks.
psergiu
Posted: 10:01am 10 Jul 2013
Correction: You need to reset the device or use the NEW command in order to be able to use playmod again.
Posted: 03:27pm 10 Jul 2013
This is a problem with recovering cleanly from an error, a subject fraught with problems. I will fix it in the final release of 4.4 (due soon).
psergiu
Posted: 02:27pm 11 Jul 2013
Another related one (sorry if it's for the same bug)
- copy FILE.MOD to a:
- WRONG.MOD not not exists
PLAYMOD "A:WRONG.MOD"
- Error: Cannot find file
PLAYMOD "A:FILE.MOD"
- No error returned but module is not played. value of MM.ERRNO is 6
- All further calls to playmod give the error "Only one internal flash file can be open at a time"
Posted: 03:41pm 11 Jul 2013
That is a new bug, thanks. I will also fix that in the final release.
