Local Time 11:32 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CHDIR command
Nick
Posted: 09:37am 26 Jun 2013
If I have a file structure that is several directories deep.
eg.
B:\DIR1\DIR2\DIR3
and I am currently in DIR3
How do I, in a single command, change back to B:\ ?
I know CHDIR .. takes me back one but CHDIR B:\ doesn't work.
Nick
Dylan
Posted: 10:38am 26 Jun 2013
..\..\.. perhaps?
Dylan
Posted: 10:41am 26 Jun 2013
wait, chdir never takes a drive anyway. Just chdir \ is supposed to work.
(each drive remembers its path)
Posted: 11:10am 26 Jun 2013
Probably CHDIR B:\
BobD
Posted: 11:30am 26 Jun 2013
  Dylan said   wait, chdir never takes a drive anyway. Just chdir \ is supposed to work.
What he said. Follows is a quote from the V4.3a manual.
Change the current working directory on the SD card to ‘dir$’
The special entry “..” represents the parent of the current directory and
“.” represents the current directory.
It looks like you set DIR$ first then issue CHDIR it seems an odd way to do it.
shoebuckle
Posted: 12:52pm 26 Jun 2013
  Nick said   If I have a file structure that is several directories deep.
eg.
B:\DIR1\DIR2\DIR3
Nick
As Dylan says"
CHDIR "..\..\.."
will get you back from DIR3 to B:\
Cheers,
Hugh
paceman
Posted: 03:38pm 26 Jun 2013
  shoebuckle said   As Dylan says"
CHDIR "..\..\.."
Hugh
Well, there's an answer I should have asked the question to long ago. I've always kept the directory structure just one level deep because of this and it's made my directory lists rather longer than I'd like.
Greg
Nick
Posted: 03:51pm 26 Jun 2013
Yep. Leave out the drive letter.
I don't know which OS I was thinking. :)
Nick
Juri74
Posted: 10:57pm 26 Jun 2013
Hello Nick!
if you want to go back to the root, no matter what subdirectory you are, try
Chdir "\"
Juri
Dylan
Posted: 07:41am 27 Jun 2013
  Juri74 said   Hello Nick!
Chdir "\"
Juri
I must admit, using the quotes is something I fail to do!
