Local Time 11:33 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reading Excel files with MM-BASIC
FuzzyPanda
Posted: 11:15am 24 Jun 2013
This is my first time working with mm-basic so I'm still reading up on the documentation. I have a duinomite mega that I wish to use in a project where by a value is read from a table which alters the result of another value which needs to be matched up on the table. my question is can the duinomite or mm-basic read excel files or would I have to or be able to use another language to do the job?
jman
Posted: 12:10pm 24 Jun 2013
Hi
Why not make your files CSV format then MMBasic can read them
FuzzyPanda
Posted: 12:51pm 24 Jun 2013
Thanks I will try that.
One more question. I plan on using the SPI function to output the data but the IC that I am using does not have a digital out and so I only require MOSI and not MISO. How would I go about writing the code so that I can just output data to the IC then recieve data from another IC?
Adam
