Local Time 11:33 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : settick
centrex
Posted: 12:33am 24 Jun 2013
Can anyone show me a few lines of code that demonstrate how to use SETTICK and IRETURN.
thanks
cliff
Cliff
Posted: 01:16am 24 Jun 2013
[code]
'Every second
SETTICK 1000, ShowTime
'Endless loop until a key is pressed
'If you do not have this your program will END
DO WHILE INKEY$ = "": LOOP
ShowTime:
PRINT TIME$
IRETURN
Edited by TZAdvantage 2013-06-25
Nixie
Posted: 11:53am 24 Jun 2013
Hmmmm I also still haven't got a grip on the SETTICK command.
I've looked at the notes, but it still hasn't stuck with me.
When it was mentioned to me in a post, a long time ago, I did have a play. But I too couldn't find much info in the manuals - especially in examples and also on this site.
Perhaps I missed something?
I solved what I was doing with TIMER and PAUSE. So if someone cold explain the value in this command, I'd e most grateful for enlightenment! Thanks, Nic.
Posted: 02:38pm 24 Jun 2013
For my data acquisition application, I wanted to read some of the data every second and the remainder every 10 seconds.
using :
SETTICK 1000,_readAll
and then in the _readAll sub:
...do the one second stuff
ticks=ticks+1
if ticks mod 10=0 then... do the 10 second stuff
etc
It doesn't matter how long the routine take provided its less than the settick interval.
the SETTICK 1000 does all the time keeping.
If you have a routine that might take longer than the interval such as waiting for user input. use SETTICK 0,0 to disable it and then restart when the slow routine has finished.
panky
Posted: 04:20pm 24 Jun 2013
..... or simply,
SETTICK is an interrupt driven timer that has two arguments; the interrupt interval in milliseconds and a label that points to an interrupt service routine which must end with IRETURN.
Cheers, Doug.
Posted: 04:51pm 24 Jun 2013
  TZAdvantage said   [code]
'Every second
ShowTime:
PRINT TIME$
IRETURN
shouldn't there be some sort off exit or stop statement after the "DO WHILE" loop to stop the program executing the interrupt routine once after a key has been pressed and throwing an error (?) when it hits an IRETURN that has no place to return to?
Posted: 05:13pm 24 Jun 2013
Good point.
I am used to SUB or FUNCTION and those are not run when you press a key.
The subroutines with a label are something that have to be used with interrupt routines. I read Geoff is planning to add SUB and FUNCTION called from interrupts. That should prevent small errors like this.
I try to avoid subroutine labels and use them only when absolutely necessary.
centrex
Posted: 10:53pm 24 Jun 2013
Thanks TZ
It worked perfectly, now I know what I am looking for.
Thanks to all the others as always you are helpful.
Cliff
Cliff
Nixie
Posted: 11:47am 25 Jun 2013
Thanks to all. That has given me a much better grip on SETTICK - much appreciated!
Cheers, Nic
