Local Time 10:40 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Soft RESET for the MM?
Posted: 02:44pm 19 Jun 2013
Hi all.
I was looking at possibly resetting the MM in the code.
I can't see any command for that in the manual.
Perhaps it can be done by poking a memory location?
Other then that, I can use an I/O pin, pulled high with an external 10k or so, connected back to ~MCLR and pulse it low in the code to force a reset, but is there any way to do that in code with a simple command?
Does not matter if not - I will just use the I/O pin method.
I plan to have a "RESET" push button on the system, but I am not willing to put this directly on ~MCLR, as if the SD card is writing especially, resetting during a card write is not a good thing.
So, I was going to have the "RESET" button connected to a normal I/O line and setup an interrupt for that line, so that if it is ever pressed, it will loop to a short bit of code which just closes any open files, then performs a soft-reset to restart the system.
Posted: 04:37pm 19 Jun 2013
Often a user reset button is connected to a non maskable interrupt to do the reset under software control.
A tiny button hidden behind a small hole is the one that is connected to the reset line. Having both is good otherwise people just recycle power.
You would need a small battery or a (super)cap to provide enough power and an input line to detect the power loss to safe important info when that happens.
Juri74
Posted: 11:42pm 19 Jun 2013
Hello grogster,
for a fast software reset try POKE 1,1,1
Posted: 11:54pm 19 Jun 2013
Poke 1,1,1 crashes the system, it does not reboot it...
Posted: 12:37am 20 Jun 2013
If you setup an interrupt on an i/o port then you could use this:
[code]
handleInterrupt:
'close files here if necessary
CLS
Print 'Restarting.....'
RUN "YOURPROGRAM.BAS"
IRETURN
[/code]
This will reboot the BASIC program.
Edited by TZAdvantage 2013-06-21
Juri74
Posted: 05:34am 21 Jun 2013
i think i found a bug... surely pokeing here and there in memory will end in a crash, ofcourse!
poke 1,1,1 is a proof of it.. but shouldn't be safe peeking memory? even theese critical memory locations?
try
PRINT PEEK(1,1)
Juri
Posted: 12:27pm 21 Jun 2013
No, that is referring to an illegal address and the hardware in the PIC32 catches it and forces an exception (this is out of the control of MMBasic).
Theoretically it is possible for MMBasic to validate the address before it attempts to use it but there are so many valid/invalid addresses in the PIC32's memory map that it would be too complex and error prone.
Dylan
Posted: 01:25pm 21 Jun 2013
I think I tried PEEK(1, 1) too - unless I was trying to peek 1fc/bfc the other month. Slow learner.
