Local Time 10:20 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM and Linux
BobDevries
Posted: 11:20am 21 May 2013
Hi all,
Has anyone here had any success in connecting the MM to a Linux terminal programme?
I have tried "minicom", but its use is limited in that it doesn't appear to transmit all the keyboard keys, in particular the function keys (F1... etc)
If the F keys don't work, I can't use the MM full-screen editor.
Bob Devries
Dalby, QLD, Australia
ThierryP
Posted: 12:21pm 21 May 2013
Bob
I'm using minicom and most times picocom without problems, incl F-keys and Esc.
Only keystroke I have difficulty with is Ctrl-C.
Thierry
crackerjack
Posted: 09:13pm 21 May 2013
Hi Bob,
I use minicom - the only issue I had was I could not get the F-keys (1 thru 4) to work. Minicom kept sending ESC-OP, ESC-OQ, etc.
So I setup some macros, to send characters Hex 91, etc (see the MM Manual for the details of which characters to send in one of the Apendices - I can't recall them right now). I just moved the F-keys from 1 - 4 to 6 onwards. Having done that the Fill Screen editor is usable again. Don't forget to set the size of your terminal window to 80x36 and then do a resize command before starting minicom.
Good luck.
If you can't get it right, shout out and I'll be more detailed in reply.
panky
Posted: 11:41pm 21 May 2013
Bob,
Have a look at my post 'DM Inerface to Linux' on previous page - I went the Virtual Box route as I knew TerraTerm would work with function keys but also that I could use the Windows only MMEdit (fantastic program Jim) and MMIDE (fantastic program CG) natively under XP as well as Geof's DOS MM.
I am in the process of a detailed write-up on install/config of this scenario for both the boys above - will post soon when ready.
Cheers, Doug.
Posted: 03:11am 22 May 2013
I use screen and it does all I want.
ThierryP
Posted: 05:22am 22 May 2013
  ThierryP said   Bob
Thierry
Meant to say:
I can use Ctrl-C, but I can't interrupt an already running autorun.bas program on the MM/DM from a Teraterm terminal that is logging into a remote Linux PC / Embedded system, that is physically connecting to a MM/DM via USB (picocom -b 115200 /dev/ttyACM0).
However, if I start the autorun.bas (or any .bas) from the terminal, I can interrupt it via Ctrl-C, any suggestions?
vasi
Posted: 10:37am 22 May 2013
A fast solution. I don't know what version of linux you have, but if Arduino is available, just install it. It have a serial terminal you can start.
Other solutions: cutecom, gtkterm - also, don't remember if I mentioned them on the other topic?
Elvish name: Mablung Miriel
Beyound Arduino Lang
crackerjack
Posted: 04:27pm 25 May 2013
Hi JohnS,
I am trying out GNU Screen (an interesting concept is Screen - and a utility I was not aware of - so thanks for pointing it out). Works fine (with some modified key bindings for backspace, etc.), but I am unable to send a Ctrl-C to the *Mite connected to it to stop a running program... Have you (or anybody) any experience with this and could possibly suggest a fix/workaround or appropriate keybinding?
Thanks in advance...
[EDIT] I have done the pre-requisite Googling to no avail...Edited by crackerjack 2013-05-27
