Local Time 10:20 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Smaller Smaller
vk4tec
Posted: 12:51am 18 May 2013
I am inspired
I have played with
DunioMite
MaxiMite
MegaMite
mini Maximite
What is the smallest footprint ?
I like MMBasic as it take the pain out of the PIC32 in Assembly.
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
Posted: 03:07am 18 May 2013
Assembly!!!!
At least use C :)
Like Geoff and others do.
JohnEdited by JohnS 2013-05-19
vk4tec
Posted: 03:19am 18 May 2013
I learnt assembly from a friend
It made me understand what the PIC is doing inside
And thats important later on
When you understand what bits get set and why
- Andrew -
Andrew Rich VK4TEC
kiiid
Posted: 01:10pm 18 May 2013
This is the smallest footprint: http://dimitech.com/?p=282
http://rittle.org
MOBI
Posted: 02:46pm 18 May 2013
  Quote  I learnt assembly from a friend
Each to his own and each has its place.
I use both depending on the size of the project. When it comes to programming an 8 bit PIC (e.g F88) I generally use assembly. I grew up with it in the MPU days. I found that it teaches the brain to think a little more abstractly than using a higher level language, and these days, the brain needs all the excercise it can get.
Perhaps using assembly is a bit like building a project using "real" components. It all depends on what gives one the biggest kick.
Sorry, I don't really mean to hijack this thread.
David M.
Posted: 07:39pm 18 May 2013
This is the smallest that I have seen: http://www.youtube.com/watch?v=LUMnO5p-fjg&lr=1
The whole Maximite is where the three cables join.
kiiid
Posted: 09:21pm 18 May 2013
  Geoffg said   This is the smallest that I have seen: http://www.youtube.com/watch?v=LUMnO5p-fjg&lr=1
No Geoff, it's bigger and needs external power as well
Edited by kiiid 2013-05-20
http://rittle.org
donmck
Posted: 10:41am 20 May 2013
I believe this is the cheapest by a long shot:
http://www.dontronics-shop.com/olimex-duinomite-mini.html
Don...
https://www.dontronics.com
jacques1
Posted: 02:31am 24 May 2013
  kiiid said   This is the smallest footprint: http://dimitech.com/?p=282
Really it's have smallest footprints.
Agm Batteries
djuqa
Posted: 09:22am 24 May 2013
Who really cares
They are ALL SMALL!
The Duinomite-mini has the best overall design
Compact size; I/O connectors; mounting holes, Cost.
Dimitech module is a great idea for embedded solutions but can't stand-alone.
Edited by djuqa 2013-05-25
VK4MU MicroController Units
