Local Time 09:49 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM: help needed
Juri74
Posted: 02:16am 16 Apr 2013
hello all..
i'm experiencing troubles with file management with color maximite / ubw32
i do not know if it's a bug or if my ubw32 have problems so i'll post a test program here asking some help, try it and let me know if your maximite will reboot without any reasons..
i attach a zip file containing the test.bas file and a jpg file called "fridge.jpg"
all you have to do is to run the test program, give for input file the "fridge.jpg" and any name for output file..
you can use any other files but i encouter that fault with files bigger than 2kb
Input "infile";a$
Input "outfile";b$
Open a$ For input As 1:Open b$ For output As 2
x=0
x=x+1:t$=Input$(1,#1):Print #2,t$;
Print @(0,0)"bytes processed";x;Space$(20)
If Eof(1)=-1 Then Close 1:Close 2:End
the program simply copy the input file to output file byte by byte..
thank you..
Juri
2013-04-16_121454_Test.zip
Posted: 01:01pm 16 Apr 2013
I have changed your test.bas slightly to speed up the process.
Input "infile";a$
Input "outfile";b$
x=0
cls
if (x mod 100) = 0 then Print @(0,0)"bytes processed";x;Space$(20)
If Eof(1)=-1 Then exit
loop
Close 1:Close 2
Print @(0,0)"bytes processed";x;" All completed!"
end
Printing every 100 bytes makes a big difference to the time taken
I have run the program 6 or 7 times so far without any problems.
Using a UBW32 with MM Basic V4.3a and connected to a PC rather than a keyboard and screen.
The schematic shows a 2.2 ohm resistor between 3.3V and pin 4 of the SD card holder.
There was some discussion about this resistor and I think some users had more success if this resistor was replaced with a link.
I would certainly try a different brand of SD card.
