Local Time 09:49 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD Touchscreens
OA47
Posted: 09:24pm 14 Apr 2013
It has been some time since the subject has been raised on this forum, so I was wondering if any of the "projecteers" have recently found some reasonably priced LCD touchscreens that can be simply interfaced with MMBasic? The "el cheapo" units that I see on 'bay seem to have an SPI touch interface but if I am not mistaken they will consume many of the I/O ports on the processor for the video. Would like to hear from any members with hardware or software solutions they have applied.
Posted: 09:32pm 14 Apr 2013
The screen I am using came with a touch controller but I found it easier to forget about that and drive the resistive panel directly.
It still requires 6 IO ports but at least I have the ability to choose which ports are used.
Any resistive panel should be easy to drive with the maximite. The capacitive ones will need a controller.
I haven't done any more with it but hope to get back to it soon.
http://www.thebackshed.com/forum/forum_posts.asp?TID=5319&KW =touch+screen
Zonker
Posted: 06:09pm 17 Apr 2013
I have a touch LCD Display project going on using...
http://www.4dsystems.com.au/
It seems to be working out so far...
OA47
Posted: 06:20pm 17 Apr 2013
Zonker, can you elaborate on the particular 4dsystems unit you are using and the interfacing that you are using?
Zonker
Posted: 05:15am 18 Apr 2013
Sure... I currently have the µLCD-144-G2 (good for simple interface) (no touch)...
also have the µLCD-32WPTU (with touch) and am designing a test fixture at work for testing IGBT driver PCB's (see pix)... Also have the µLCD-43 (P/PT/PCT) unit and using it to design an "engine information system" for ultra-light aircraft. (nice)
Anyway, the thing is, they all use a simple serial com interface. You can write your own code that runs inside the GPU, or go code-less, as I did !.. Just layout your active objects and compile... It uses a simple com protocall to let the Maximite know what the user is doing..! (sweet)
Check it out...!
use this code "snippit" to send data to objects...
Function tx_object(o_id,o_num,data)
chksm=0: msb=0: lsb=0
chksm=chksm Xor 1: chksm=chksm Xor o_id: chksm=chksm Xor o_num
If data >= 256 Then
msb=data\16: lsb=data And 255
Else
lsb=data
chksm=chksm Xor msb: chksm=chksm Xor lsb
Print #3,Chr$(1) Chr$(o_id) Chr$(o_num) Chr$(msb) Chr$(lsb) Chr$(chksm);
End Function
or this to receive button touches..ect...
chkbuf:
rxbytes=Loc(#1)
If gotpacket=0 And rxbytes>=6 Then
chksum=0
rxdat$=Input$(1,#1): msgtype=Asc(rxdat$): chksum=chksum Xor msgtype
rxdat$=Input$(1,#1): obj_id=Asc(rxdat$): chksum=chksun Xor obj_id
rxdat$=Input$(1,#1): obj_num=Asc(rxdat$): chksum=chksun Xor obj_num
rxdat$=Input$(1,#1): datMSB=Asc(rxdat$): chksum=chksun Xor datMSB
rxdat$=Input$(1,#1): datLSB=Asc(rxdat$): chksum=chksun Xor datLSB
rxdat$=Input$(1,#1): datXOR=Asc(rxdat$): chksum=chksun Xor datXOR
rxbytes=Loc(#1): chksum=chksum Xor datXOR: obj_val=datMSB*256+datLSB
If msgtype=7 Then gotpacket=1
Return
