Local Time 09:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Closed Loop Position Control!
StoveMan
Posted: 04:41pm 01 Apr 2013
Hi All,
Just a head's up for anyone wanting to drive a motor to a specific position and hold it. Check out the Kangaroo X2 from Dimension Engineering http://www.dimensionengineering.com/products/kangaroo
It interfaces with their great line of motor controllers (5-60A) and:
Auto-tunes for any servo (VERY COOL INDEED!)
Has stall/crash detection so no limit switches needed at ends of travel
Has encoder or pot interface for feedback
Serial control with multidrop
Is real cheap for all the coding you save
I use these with Polulu's line of 37mm motors which have magnetic encoders. They are super easy to drive from MMbasic with the 'simplified serial' protocol!
You can turn them into a HD hobby servo with custom range or build that 6 axis CNC Mill running a G-Code interpreter on a MMite.
Frank
