Local Time 09:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM TIME$ PLEASE? Where X<>1 !!!
Nixie
Posted: 08:46pm 30 Mar 2013
Instead of X equalling 1, it doesn't !
If I adjust the PAUSE to 1000, yes it all behaves itself. But I can't afford to do that because I want to use it without using PAUSE in a program where I want to measue times of less than one second. I know I could cheat by using what X turns out to be, but I'm hoping for a more elegant solution?
Any assistance greatly appreciated. Using an original BW MM with ver 4.3 firmware/ mmbasic.
THE PROGRAM:
100 CLS: M=0
120 S=VAL(MID$((TIME$),7,2)) 'S= the number of seconds from the internal clock
130 IF S=59 THEN M=M+1 'Increment the counter M every 60 seconds
140 PAUSE 200 'Without PAUSE X=310 on the first pass!
150 PRINT M,S
160 IF M=3 THEN END
170 GOTO 120
ONSCREEN RESULTS:
0 58
0 58
1 59
2 59
3 59
4 59
5 59
5 0
5 0
5 0
5 0
5 1
5 1
Etc..
Many thanks, Nic
"Biggles Smiled Grimly"
Nixie
Posted: 08:58pm 30 Mar 2013
Oh dear, I did mean M NOT X.
So sorry, my attention to detail slipped.
Thanks, N
MM_Wombat
Posted: 09:35pm 30 Mar 2013
try,
100 CLS : M=0 : flag=0
130 if s=59 AND flag=0 then m=m+1 : flag = 1
140 if s=0 then flag=0 ' reset flag for next occurrence of 59
obviously this will fill the screen with lots of values.
change 150 to 150 print @(0,30) m,s;" "
which will keep the output on one line
Regards dennis
Maximite, ColourMaximite, MM+
Posted: 09:41pm 30 Mar 2013
Nic,
Try this version:
CLS: M=0
_Lbl120:
IF S=0 THEN ' use zero rather than 59 to increment the minutes
if first=0 then ' only inc on the first time through with zero
first =1 ' set the flag to stop further incs
endif
else
first=0 ' we have passed the zero so we can reset the flag
endif
PRINT M,S
IF M=3 THEN END
GOTO _Lbl120
And then study the SETTICK way of doing things.
You can use SETTICK to run a short routine every second (or whatever period) and do the counting then return to the main program.
That way we are not sitting helpless in a pause.
Beaten by slow typing again!Edited by TassyJim 2013-04-01
MM_Wombat
Posted: 09:51pm 30 Mar 2013
Great minds think alike TassyJim.
I didn't think of the settick function, if that makes you feel any better.
1 finger typer myself...
Regards Dennis
Nixie
Posted: 01:33am 31 Mar 2013
Ah ha! I am enlightened!
Jim, Dennis, thank you, thank you! This is just so great to get assistance!
..and yes, not only have you answered a couple of puzzles, you expand my knowledge too!
Best regards, Nic.
