Local Time 09:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : You Maximiters have been busy!
jwettroth
Posted: 01:46pm 26 Mar 2013
I got busy late last year and stopped playing with my Maximite.
I followed along a bit and got notices of MMBASIC updates from Geoff but was too busy. Finally, with the availability of V4.3A, the Circuit Gizmo's CGMaximite Colour and a little break at work- I got off center and dove back in. WOW! Both of this new software and the color hardware are just excellent pieces of work, flawless. You guys have really been busy! I really loved the original B&W machine but the colour machine with the latest MMBASIC is just great. I have to flash my old mono machine too.
I really like the feature of being able to write little programs that I can type from the command line without having to use a run command. It reminds me of my old DOS days. I've made a few short programs that automate little tasks- here's a simple example:
"TD.BAS"- time and date- just type td at the > prompt
cls
print "TIME: ";time$
print "DATA: ";date$
save "td.bas"
I am going to make alias's for some of the other commands. I ran into one snag. I am used to shorthand commands of the later DOS versions- ie CD vs. CHDIR for change directory and DIR vs. FILES (as in basic). I wanted to make simple aliases this way but some of the commands can only be used on the command line, they can't be in a program. I've found work arounds for some of these issues. I'll post my results when I get it polished. I'm also considering getting the source and putting the alias's in the source directly- would this be difficult? So far I've avoided compiling the source but need to get over it.
Anyway great work guys!- I'm glad to be playing with the Maximite again- what fun!
John Wettroth
CircuitGizmos
Posted: 02:58pm 26 Mar 2013
I pushed to get the command line as a variable and I think my annoying Geoff enough about it led to the implied run command. That makes the MMBasic immediate mode just a bit more DOS-like.
Here is my simple DIR.BAS:
dirt$ = DIR$( "*.*" )
DO
PRINT dirt$
dirt$ = DIR$( )
LOOP UNTIL dirt$ = ""
