Local Time 09:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Creating .mod files
Ambertom
Posted: 07:10am 22 Mar 2013
Hello,
I am new to using the Maximite, and I would like to create my own games. How do you create the .mod files to use as sound effects for the games?
ThanksEdited by Ambertom 2013-03-23
MM_Wombat
Posted: 11:46pm 22 Mar 2013
Hi Ambertom,
You could use
OpenMPT , which is a tracker/sampler program for windows etc.
Load in t0.mod to see format of tracker files...
Very short explanation follows...
Select NEW/MOD and it will create a new file with 4 channels.
Click the Samples tab, Load in your sample(8/16 bit mono)?
click on patterns tab.
Select sample 1:
Press "s" or any key, should hear a sound , the longer you press the longer the sound plays..different keys , different notes of the same sample
Press the save button, and save with name no longer than 8 characters....
Copy .mod file onto the A: drive of the maximite...
type playmod "a:(name of file).mod"
should hear your sound played..
Regards Dennis
Edited by MM_Wombat 2013-03-24
Maximite, ColourMaximite, MM+
Ambertom
Posted: 04:25am 25 Mar 2013
Thanks MM_Wombat
I'll try that and see what I can come up with.
Is there anyway to convert other sound files to .mod? I would like to play some background music during game play as well. Or is there a place with lots of .mod files that you can download?
Thanks,
paceman
Posted: 03:40pm 25 Mar 2013
Thomas,
This is from Geoff's Color Maximite article in the Oct 2012 edition of 'Silicon Chip' magazine.
"...One of the largest (mod) libraries is at: Mod music library. You can create your own music using a 'tracker'. This is a music sequencer that allows the user to arrange notes on a timeline across several channels. An example of a tracker can be found at Tracker".
Edited by paceman 2013-03-27
