Local Time 09:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CGCOLOURMAX1 RESET?
Posted: 09:14pm 15 Mar 2013
The RESET hole(right beside the SD card holder) - where is this connected to?
I traced it visually, but it disappears under the PIC32 chip, so what pin is this connected to?
I assume this is an active low input?
(pull low to reset the PIC32)
I want to connect an external watchdog to this reset line, but need to make sure that this line goes to the right place first.
Edited by Grogster 2013-03-17
CircuitGizmos
Posted: 05:17am 16 Mar 2013
It goes to the PIC reset. Active low.
