Local Time 09:23 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM: Some light on fonts..
Juri74
Posted: 09:58am 15 Mar 2013
hello :)
APPENDIX E report:
.....Each character can be up to 64 pixels high and 255 pixels wide. Up to 255 characters can be defined.
then some lines below it report:
The character numbers must be in the range of 20 to 126....
so, is it or not is it possible to edit & use characters from 127 to 255?
if i try to load a font with caracters over char 126 mm basic report an error, so
why i can have up to 255 characters defined if i can't use it?
am i doing something wrong?
JuriEdited by Juri74 2013-03-16
BobD
Posted: 10:40am 15 Mar 2013
  Juri74 said   hello :)
APPENDIX E report:
That is certainly what the book says. Looking at I would have expected the range to be decimal 32 to 125 inclusive which is the range of printable characters but who am I to argue about getting extra.
Yes, you didn't believe the manual even when you proved it correct.
