Forum Index : Microcontroller and PC projects : MM DIM "Glitch with ’S’ !"
Nixie
Posted: 09:49pm 04 Mar 2013
((These things are to keep me sharp Geoff :-) ))
Something to be aware of:
If I enter "DIM AS(100)" and then LIST or use the EDITOR, it always comes out as
"DIM As(100)" - always lower-case 's'
Trouble is when using other commands such as PRINT AS in the same program, it can't find it because AS has been stored with the DIM statement as "As".
Doesn't seem to do it with other letters. I tried DIM AN(100) - not a problem.
Just seems to be something with the letter "S"
ALSO:
at the command prompt
AS=1 (or As=1)
PRINT AS (or PRINT As - gives the results as:)
Error: Invalid syntax in both cases
BUT
AB=1
PRINT AB
1
Ab=2
PRINT Ab
2
(Biggles is still smiling grimly!)
Cheers, all - Nic.
MM_Wombat
Posted: 12:06am 05 Mar 2013
Is this because 'AS' is a reserved word. used in
open "com1:9600" As #1
or
font load "myfont.fnt" As #4
or
open "mytext.txt" for input As #1
You probably can't have a dimension statement for
TO or FOR or OR or AND or NEXT etc..
Dennis
Maximite, ColourMaximite, MM+
Nixie
Posted: 12:15am 05 Mar 2013
Ah Dennis - thanks!
That does explain it!
I can sleep tonight.
