Local Time 08:57 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Control Key
Juri74
Posted: 04:23am 17 Feb 2013
i looked through topics but i didn't found nothing useful, my question is simple:
is it possible to check if the control key is pressed? val(inkey$) does not give significant value if control key alone is pressed...
Juri
Posted: 07:03am 17 Feb 2013
My MM is on the operation table. :)
You could try:
KEYDOWN
Return the decimal ASCII value of the PS2 keyboard key that is
currently held down or zero if no key is down. The decimal values for
the function and arrow keys are listed in Appendix F.
Note that this function will only work with the attached PS2 keyboard
and the character will still be entered into the input keyboard buffer
(including repeated characters if the key is held down long enough).
But i am not sure the Ctrl key gives a code as it is normally used as a key modifier.
MM_Wombat
Posted: 01:59pm 17 Feb 2013
Hi Juri,
The control key is, as TZA said, a modifier key..
I ran this little program
do
temp$=inkey$
if temp$<>"" then
? asc(temp$)
endif
loop
I also used "print keydown" inside a do-loop...
When I pressed the control key by itself, nothing appeared on the screen, but when I pressed control-a I got a 1, control-b a 2, control-c ended the program for obvious reasons.. Shift and windoze keys work the same... alt is asc of 139
DennisEdited by MM_Wombat 2013-02-19
Maximite, ColourMaximite, MM+
Juri74
Posted: 04:04am 18 Feb 2013
that's true but strange, because a lot of pc games use CTRL key as fire button, even with ps2 keyboards, so this key alone could be checked if pressed, maybe is a maximite basic "actual" limit...
