Forum Index : Microcontroller and PC projects : Nested GOSUBs
OA47
Posted: 07:22pm 28 Jan 2013
I have been testing some code that I wrote that operates outputs at preset times. The code ran happily for about 5 days operating outputs until midnight that night when the code had to do some housekeeping (day of week etc)it crashed with the Error "Too many nested GOSUB" I have looked through the MMbasic Language Manual (V4) in particular the "Implementation Characteristics" area but cannot see a limit on the nesting of GOSUB's. Is there a limit and if so how would you check the number that the program has nested?
Posted: 09:50pm 28 Jan 2013
The topic came up for discussion about 12 months ago.
http://www.thebackshed.com/forum/forum_posts.asp?TID=4469&PN =31
MM Basic has come a long way since then but I think the limits are still the same.
OA47
Posted: 10:07pm 28 Jan 2013
Thanks TassyJim,
In that discussion Geoff has stated that the limit is 250. This number seems to be ample but I will have to check back thru my code and set a counter to see where I am coming unstuck.
djuqa
Posted: 11:00pm 28 Jan 2013
I would be totally revisiting the code
5 Nested GOSUB would be a nightmare to debug
More than 250 Bloody Heck!
VK4MU MicroController Units
OA47
Posted: 11:15pm 28 Jan 2013
Djuqa, The program has been trimmed to around 1100 lines of code, I have had to do this because I was running out of memory. If I have to do a major re-write I may have to put it on the back burner.
BTW
Even though there is no women around to hear him, she would know that he is still wrong.
Posted: 12:07am 29 Jan 2013
250 is a lot. I suspect that there is a subroutine where it will call itself.
That can get the count up real quick.
Posted: 10:09pm 29 Jan 2013
In an effort to save a little memory later versions have reduced the maximum number of nested GOSUBs to 100. Still a lot.
OA47
Posted: 11:05pm 29 Jan 2013
Thanks for the update Geoff. As I havn't got enough memory for colour which version was wound down to 100 nested GOSUB's ?
Posted: 11:35pm 29 Jan 2013
  Graeme Meager said   Thanks for the update Geoff. As I havn't got enough memory for colour which version was wound down to 100 nested GOSUB's ?
Not sure without a lot of digging, probably 4.0. You can test it easily enough on the version that you are using.
GOSUB TST
TST:
A = A + 1
PRINT A
GOSUB TST
OA47
Posted: 04:06pm 02 Feb 2013
Checked previous versions, Versions 3.XX have 250 nested GOSUB limit and Version 4.0X have 100 limit.
graynomad
Posted: 01:43pm 03 Feb 2013
Even 100 is a limit you should never get remotely close to...unless of course you are doing some recursion.
Rob Gray, AKA the Graynomad, www.robgray.com
panky
Posted: 10:20pm 05 Feb 2013
I agree Rob, I'm not a programmer but nesting GOSUBs in some form of loop that would get up to 100, particularly recursion and with the practical limits of the MM seems like a recipe for debugging hell and a future nightmare in the making.
Graeme, as an (not overly smart) observer, seems to me you might need to re-think your program structure. Not trying to teach you how to suck eggs, just a suggestion from my own experience,
Regards, Doug.
Posted: 12:42am 06 Feb 2013
For cute things like Sierpinski curves and various other mathematical curios you might use a lot of recursion but otherwise I'm with you that it's unlikely to be needed.
Cmon Microchip let's have more RAM or an external memory bus...
graynomad
Posted: 01:04am 06 Feb 2013
Yeah I've used recursion many times, easy enough but you can get into trouble.
