Local Time 08:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Pin protection
MM_Wombat
Posted: 02:09am 21 Jan 2013
Hi all,
I want to connect the maximite to a computer power supply. 350W
The 12 V line and GND (comp psu) would connect into a regulated power supply(jaycar KA1797), that has a max output of 1A at 9V, which in turn would plug into Maximite power socket.
The 5V line and ground (comp psu), would plug directly into the daisy chained DMD's (Dot Matrix Displays), 9 currently, with 21 in pipeline, as per their respective connectors.
Pins 1 to 4 , and 7 to 9 connect to the DMDCON(nector)[seperate from power connector) for control of the DMD panels, using the command spiDMD().
Pins 15, 16 , GND, and 3.3V from Maximite will power the Wifly Module and com1: connection to the wifly....
Do I need to protect the pins from unwanted spikes/surges?
The main need for the computer PSU is for the DMD panels... 4,608 led's
Or will all be ok?
Regards Dennis
Maximite, ColourMaximite, MM+
Posted: 02:16am 21 Jan 2013
Hi Dennis,
Why not just supply the MM with the 5V supply via the USB connector.
No need then for the 9V PSU.
As to protection... if these displays are to bve used over any distance you could use Opto-Isolators ... I wouldnt worry about your WiFly though
MM_Wombat
Posted: 02:27am 21 Jan 2013
Hi Mick,
There is no computer motherboard. Only a PSU, NO USB to plug into. Is for an embedded controller type project, for an outdoor display. hence the wifly, to change text from inside the building..
  Quote   if these displays are to bve used over any distance
The display will need to be viewed from a distance.. Panel will measure 960 mm x 1120 mm.
9 lines of text x 16 characters
Regards Dennis..Edited by MM_Wombat 2013-01-22
VK2MCT
Posted: 10:41am 21 Jan 2013
Hi Dennis,
I've used a pc power supply to power a MaxiMite.
I used the 5v standby PS output (on 20/24pin conn) to feed the Maxi via USB.
(Retrieved a 20/24 conn from old motherboard, and cut/sacrificed a USB cable).
The 5v standby power is usually used by a Mobo even when the power supply is 'off'.
I used a low power FET, controlled by a Maximite pin, to switch the power supply 'on' when needed - via green wire on 20/24 pin conn.
In my project this allowed external relays etc to be 'set' by Maxi, before main power was turned on.
regards,
John B
VK2MCT
Posted: 12:06pm 21 Jan 2013
....... cut/sacrificed a USB cable).
Thats a good idea to use the 5V standby and power the supply as required via a mosfet or transistor ....
The sacrifice a cheap USB cable was exactly the idea I had in mind for powering the MM.
