Local Time 07:44 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colour Maximite Music
TASMA
Posted: 02:12pm 20 Dec 2012
Hi, I downloaded the music demo program, but cannot get it to run, only get error message,"Incorrect expression syntax". I did copy T1, T2,T3 to A Drive. Any suggestions.
Brian
Posted: 03:19pm 20 Dec 2012
Where did you download the program from?
What version of MMBasic are you running?
The error message should also give the line number which the error occurred on.
TASMA
Posted: 03:56pm 20 Dec 2012
Hi Jim, I downoaded the programme from Geoff's website and I am using 4.1 version, the line number was [13] OPEN "A:T" + CHR$(48 +i) ".MOD" For Input As # ""
Brian
Posted: 04:41pm 20 Dec 2012
OK
That line should read
Open "A:T" + Chr$(48 + i) + ".Mod" For input As #1
In the file I looked at it ended in #1""
which 'might' work but in the line you have the missing file number is the problem which caused the "Incorrect expression syntax".
TASMA
Posted: 05:01pm 20 Dec 2012
Hi Jim,
Thanks very much, that fixed the problem.
Brian
