Local Time 08:23 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : @ Geoff
plasma
Posted: 11:31pm 15 Dec 2012
What do you think about a Setorientation Comand to turn the videooutput by 90 degree?
is it easy to implement ?
ajkw
Posted: 12:09am 16 Dec 2012
Have you tried loadable fonts? Just make your own set at 90 degrees and place them where-ever you want.
Posted: 02:14am 16 Dec 2012
Wow, why do I get the hard ones
Yes, I guess it could be done but aaarrrgghh!!! Easy it would not be.
plasma
Posted: 05:24am 16 Dec 2012
ah ok no problem ;)
thx
Posted: 10:24am 16 Dec 2012
I want to display on a monitor which is set for reversed video to suit a rear view camera.
The simple solution is to use a used defined font and do as ajkw suggested.
As long as I keep the text to a minimum, it wont be too hard.
A reversed font and a subroutine to reverse the order of any strings before printing.
hitsware
Posted: 05:22pm 16 Dec 2012
  Geoffg said   Wow, why do I get the hard ones
how about 4 pins set for 4 separate frequencies .......
pwm optimal but squarewave ok .........
I.E.
FREQOUT Pin , Frequency
Posted: 04:03am 17 Dec 2012
I.E.
Ar, sorry but any reasonable frequency (ie, above 500Hz) needs a hardware timer/compare and all of them are already being used for other duties.
pcaffalldavis
Posted: 09:04am 19 Dec 2012
Doesn't a reflection of a reflection accomplish the same thing? How about turning a regular display around and putting an intermediate mirror in a location where it can be viewed from the primary mirror. Might work depending on the physical limitations if any.
hitsware
Posted: 11:19am 24 Dec 2012
DuinoMite has only 1 channel of TONE or PWM
even though it has a stereo out jack.
(Both channels have same frequency (or duty cycle))
Is this hardware or software limitation ?
Posted: 11:26am 24 Dec 2012
Hardware.
You need a Colour Maximite or UBW32 running Colour MM firmware to get both channels.
hitsware
Posted: 04:14am 27 Dec 2012
  TassyJim said   Hardware.
http://www.sparkfun.com/datasheets/DevTools/PIC/UBW32_MX795_ v262.pdf
I don't see any PWM or TONE outputs ?Edited by hitsware 2012-12-28
BobD
Posted: 04:21am 27 Dec 2012
That URL link is broken.
hitsware
Posted: 04:25am 27 Dec 2012
http://www.schmalzhaus.com/UBW32/EE/v26/UBW32_MX795_v26_sch. pdf
Yea..........Wierd.........I'm pasting from where I'm getting it,
but won't work from here ? I'll try again
http://geoffg.net/Downloads/Maximite/Colour%20Maximite%20on% 20the%20UBW32.pdf
This one shows the audio outs ^Edited by hitsware 2012-12-28
BobD
Posted: 04:34am 27 Dec 2012
Try using the Add Hyperlink button on the editor toolbar. 4th from left.
hitsware
Posted: 04:45am 27 Dec 2012
Try using the Add Hyperlink button on the edit http://geoffg.net/Downloads/Maximite/Colour%20Maximite%20on% 20the%20UBW32.pdf or toolbar. 4th from left.
Thanks ..... AwkwardEdited by hitsware 2012-12-28
Posted: 10:38am 27 Dec 2012
That is because `The Back Shed' adds a random space to long lines (for some anti spamming reason.)
To post an URL properly click on the Chain link symbol and you will post it like this
Correct link
hitsware
Posted: 04:02pm 27 Dec 2012
the truth is out there ]the truth is out there[/URL] Edited by hitsware 2012-12-29
