Forum Index : Microcontroller and PC projects : How cheap can SD cards get?
I just bought two 4GB micro SD cards for $5 each. It was just a normal retailer and I originally wanted 2GB but they did not have them as that was "too small". How cheap is that? Soon we could find them in our cornflakes! One came with a full sized SD card adapter but the other came with a neat USB adapter, slip the micro SD card into the adapter and you can read it on any PC! $5 each! I can remember when 5 1⁄4-inch floppies cost $5 and they held 360K... mutter, mutter. Geoff Graham - http://geoffg.net |
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1056 |
Geoff, remember the days when we purchased singled sided floppy disks (as they were cheaper) and felt rewarded when with the use of the hole punch could double the capacity? IRRC the term was "making flippies from floppies" Ahhh the good old days |
Yes, and amazingly they were just as good as the "official" double sided floppies. I should confess, I started on 8 inch single sided single density floppies. A whole 240KB... wow! Geoff Graham - http://geoffg.net |
Yes me too. But I think they were an amazing 180 Kb capacity |
You might be right, it was a long time ago... Geoff Graham - http://geoffg.net |
When I started binary there weren't any ones. All I got were zeros. Micromites and Maximites! - Beginning Maximite |
Wow, what fantastic bargains! Unfortunately I predate floppy disks and can recall being really delighted when such wonderful devices first arrived :( John |
| MOBI Guru Joined: 02/12/2012 Location: AustraliaPosts: 819 |
I have about 400 5.25 floppies with many games, programming languages and general data that I can no longer access (no disk drive). My data storage was a modified cassette deck where I fed the data -5 0 +5 direct to the record/play head and then read it back through an op amp/transistor based schmitt trigger to recover the data. All ran at 1200bps, so now I have a box of cassettes that I also can't acces (somewhere along the line the tape recorder got too rusty and worn to use. the processor was a MC6800 running at 1MHz I started with 512bytes of ram and when the 2102 (1k x 1 bit) came out I had a whopping 1k of ram in only 8 chips! Wrote a small interpreter language that fitted into 256bytes!! Those were the days my friend ....sigh.... david m. David M. |
I admit to being that old too, My first floppies were 5.25" 68k Single sided 35 track TRS80.. Then I went for 5.25" Double sided, double density, 80 track, which we could bastardise to 85 track and get some massive storage of which I cant remember but around the 1.4Meg using LDOS as the operating system. I also had 8" on a CPM system and I remember the single sided was about 185kb Regards, Mick EDIT *** Oh and my first single sided (or maybe double sided) 40 track Floppy drives were MPI brand, bare drives, no case or power supply and cost me $400 each and I only got them that cheap because I bought 4 of them... 40track gave about 80kb Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| shoebuckle Senior Member Joined: 21/01/2012 Location: AustraliaPosts: 189 |
I too predate floppies by interfacing an audio tape recorder to Jim Rowe's Educ8 computer, with all of 256 bytes of memory! Hugh |
James_From_Canb![]() Senior Member Joined: 19/06/2011 Location: AustraliaPosts: 265 |
I ended up converting my floppies to images and they all fitted on a single CD. I've never looked at them since, but they're there just in case. I'd suggest contacting your local computer club to see if they have kept a machine with a functioning 5.25" drive and borrow it for long enough to convert the disks. Then get rid of them. There's no USB 5.25" drives that I can find with a quick check of Google, although there's an interface that might still be available. You still need the drive of course. An old machine's more convenient as it's ready to go. James My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. Hedley Lamarr, Blazing Saddles (1974) |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
I found this USB - FDD adaptor board Very interesting final line of the description [quote]High quality immersion gold coated boards produced in cooperation with, and assembled by, Olimex Ltd.[/quote] I have several old, but good condition PC's. I should rebuild one as FDD - USB - SD transfer machine. VK4MU MicroController Units |
| Georgen Guru Joined: 13/09/2011 Location: AustraliaPosts: 462 |
Not SD Card, but USB stick, it is 32GB for $25 at K-Mart now. George |
[quote=james]I'd suggest contacting your local computer club to see if they have kept a machine with a functioning 5.25" drive [/quote] I spent a couple of years trying to get others in my district interested in electronics with not a murmur of interest. I've not much chance in asking a local computer group. That's a problem with country towns. d.m. David M. |
Hi Geoff, Where did you get these from? My notebook (old XP) has a card reader that reads/writes the older 1.6mm thick standard MMC cards (MMC-16M) OK but won't read/write the newer SDHC or micro SD adapters because they're too thick at 2.15mm to fit into the slot. Either of these types are OK in the Maximites but the older ones are not that easy to find now and I'd rather not have another stand-alone reader attached to the notebook. The ones you found with the USB connector sounds just the ticket. Greg |
They came from a Perth computer shop called PLE Computers. Geoff Graham - http://geoffg.net |
Speaking of old magnetic media. I still have some cassettes with basic programs on them written IIRC at 1200 baud. Does any one have any ideas about using the mite to read this data via a tape deck and the audio port? |
