Local Time 07:44 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : voltage on 5 V pins
hitsware
Posted: 12:39pm 14 Dec 2012
~ what should the 5 V pins read if running
off usb ?
I accidently shorted the 5 V to Gnd for a
short (less than a sec)
I now read ~ 4 V, (3.3 is right on) but my
DuinoMite reads ~ 4.75 V
It seems lower than before but ?
(some op amps act differant than before
(but I hadn't actually measured))
BobD
Posted: 01:50pm 14 Dec 2012
what device are we talking about, MM, CMM, DM etc.?
Have you changed the usb cable?
Tried to a different usb port on the PC?
hitsware
Posted: 02:14pm 14 Dec 2012
CMM
Yes
Yes. Also tried differant PC
measured 0.6 V accross the Shockey diode
which is what it should be @ ~ 1 Amp ?
nothing seems hot
Posted: 11:46am 15 Dec 2012
You should only get a voltage drop of 0.3V across the Shockey diode. The minimum USB voltage spec is 4.5V so your 5V rail could get as low as 4.2V.
hitsware
Posted: 12:42pm 15 Dec 2012
  Geoffg said   You should only get a voltage drop of 0.3V across the Shockey diode. The minimum USB voltage spec is 4.5V so your 5V rail could get as low as 4.2V.
Thanks !
Could I have stressed it into the higher
drop when I grounded the 5V line ?
Posted: 02:41pm 15 Dec 2012
No, that does not sound likely, the 1N5819 is a 1 Amp diode and most USBs are limited to about 0.5A. You could check that the diode is actually a 1N5819 as other diodes can have a higher voltage drop.
