Local Time 07:29 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Suggestions for new users
James_From_Canb
Posted: 08:36pm 29 Nov 2012
There are a lot of experienced MM/DM users on this forum.
Given this is one of the first places that new users will look, what would you recommend that they get for their parts kit, where can they get it from, and why is it likely to be useful?
I'll start with some:
Soldering / Prototyping
A temperature controlled soldering station
A fine tip for the soldering iron
A solder sucker and solder absorbing braid
A magnifying glass on a stand (optional)
A stand with spring loaded clamps for holding circuit boards (optional)
One or more prototyping boards
Where from? Any electronics shop (Altronics, Dick Smith, Jaycar etc), eBay.
Why? Good soldering gear helps you to make good soldered joints. I used to be an expert at creating bad joints. Good gear is helping me get better. Prototyping boards don't need soldering, and setting up circuits is quick and easy.
Posted: 10:17pm 29 Nov 2012
For a beginner it may be best to buy a pre-built board and get used to both MMBasic and simple add-on circuits external to the pre-built board.
Later, consider DIY build (if interested) and use the original board to compare with when problems occur, if they do.
JohnEdited by JohnS 2012-12-01
