Local Time 07:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit update
Posted: 04:32pm 29 Nov 2012
MMEdit update
I have uploaded V3.1.6 of MMEdit.
When you run DOS MMBasic, it now starts in the folder that your basic program is located or the current default folder if you haven't saved your program yet. This is handy if you are trying to open files for IO.
It doesn't matter where MMBasic.exe is located.
You can now change the name of the DOS exe file. It can be called MMBasic41.exe etc
I have implemented ^[K (clear to end of line) in the VT mode to comply with MM Basic V4.1
The editor does seem to run smoother with V4.1 but you still don't want to push it too hard.
The syntax help has been updated to include PORT.
PORT is going to be a very handy command!
As usual, MM Edit is available from:
http://www.c-com.com.au/MMedit.htm
