Local Time 07:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New version of MMBasic (ver 4.1)
Posted: 05:07pm 28 Nov 2012
A new version of MMBasic (ver 4.1) is available for download from http://geoffg.net/maximite.html
This version fixes the colour shift issue with V4.0B and a few other bugs and includes a number of minor improvements.
New is the PORT command and function which has been requested a number of times. Used as a command this will simultaneously set the outputs of up to 23 I/O pins in one operation. Used as a function it will read the values of up to 23 I/O pins in one operation.
The Change Log (included in the update download) details the changes.
CircuitGizmos
Posted: 05:17pm 28 Nov 2012
I like the way you did the PORT command.
Posted: 05:36pm 28 Nov 2012
Thanks. I thought it was pretty cool too (says he modestly).
paceman
Posted: 05:47pm 28 Nov 2012
That's certainly fixed the coloured fringe for me (CGCOLORMAX) - thanks again Geoff, how you keep this up is beyond me!
Making the quotes optional for direct commands will improve my poor typing skills no end, I was forever going back to put them in - or maybe it wasn't my typing skills.
Greg
CG - shouldn't you be asleep!
palcal
Posted: 10:09pm 28 Nov 2012
Just one very small thing with the Language Manual. When describing the PORT command eight pins is 4 to 11 not 4 to 12.
elproducts
Posted: 01:26am 29 Nov 2012
This may be a dumb question and probably in the documentation somewhere that I overlooked but I'll ask anyway.
Can the latest MMBASIC 4.1 be run on any Maximite such as the CGMMSTICK1 or is there a cutoff point for support of the original style Maximite?
www.elproducts.com
CircuitGizmos
Posted: 03:36am 29 Nov 2012
  elproducts said   This may be a dumb question and probably in the documentation somewhere that I overlooked but I'll ask anyway.
The newest software will still run on the 'Stick' - just download the right file for it. 4.1 runs on the CGCOLORMAX1 and CGMMSTICK1. (different files)
Posted: 03:42am 29 Nov 2012
palcal - Thanks
elproducts - Yes, the original Maximite is still supported and don't intend to stop supporting it.
elproducts
Posted: 04:29am 29 Nov 2012
Awesome. Thanks.
I've been doing other projects whihc have occupied my time and still have an SM1 and CGMMSTICK1 sitting on my bench calling for attention and the new PORT command got me thinking I need to get back to playing with my Maximites.
www.elproducts.com
isochronic
Posted: 03:16pm 29 Nov 2012
Guessing that the nops are in assembler, has the video
been moved from C to assembler ? Also, has the temperature
effect gone /was it a different issue,
cheers
Posted: 10:24pm 29 Nov 2012
No, the video is still in C.
ajkw
Posted: 11:36pm 30 Nov 2012
When editing a file (as opposed to the program in memory) with EDIT I can pgdn past the EOF which then causes the editor to loose control of the cursor position.
Anyone else?
Anthony.
