Local Time 07:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Memory and strings
vk4tec
Posted: 11:05am 23 Nov 2012
Hi
I am now having great success with my GPS logger and I have another question
I am writing alot to the SD CARD
How much data can I build up in a string ?
Is it possible for me to dump to SD card say every 30 lines of data ?
msg$ = msg$ + line4
IF counter$ > 10 then
save to SD CARD
reset msg$
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
Posted: 02:09pm 23 Nov 2012
Strings are a maximum of 255 bytes long (plus one byte for the length).
In memory, they use 256 bytes whatever length is used.
You could use a string array to hold a number of records before saving.
Each array element would use 256 bytes so there will be a limit to the size of the array (depending on your memory usage).
