Local Time 07:21 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug in DOS MMBasic - print statement
James_From_Canb
Posted: 03:26am 14 Nov 2012
Hi.
There is a bug in DOS MMBasic 4.0. It isn't printing correctly to a file. Instead of appending a CRLF (0D0A hex) to the end of each line, it's appending a CRCRLF (0D0D0A hex).
2012-11-14_132513_ShowPrintBug.zip
The zip file contains code that demonstrates the bug and an input file of text with normal CRLFs between lines. It's copied to the file OUTPUT.TXT. Open the file in a hex editor to see the problem.
Is this the right place to report bugs? I tried reporting a previous DOS MMBasic error on Maximite.com.au, but I can't find it there.
James
PS there may be another bug where a delay is required before accessing an opened file, but I'll research it a bit more before I raise the issue.
paceman
Posted: 09:30pm 14 Nov 2012
James[/Quote]
Hi James,
thanks for looking into this. I've always known I'm not a programmer's .....
but I just couldn't see what I was doing wrong! Mind you, having a pile of lyric text files of dubious genesis (that sounds good) to process doesn't help much!
GregEdited by paceman 2012-11-16
Posted: 11:59pm 14 Nov 2012
What I thing is happening is, when a LF is printed, the system adds a CR.
You can get around it by changing your demo program to
lf$=chr$(10)
Open "test.txt" for input as #1
Open "Output.txt" for output as #2
Print #2, "Just to show it's not related to the input file";lf$;
Line Input #1, lyricLine$
print #2, lyricLine$;lf$; ' just copy it to another file
Loop Until EOF(#1)
Close #1, #2
END
We suppress the CRLF pair and substitute a singe LF for each line.
Not a permanent fix, but it might help.
I expect the problem comes about by the need to use different compilers for the different systems.
James_From_Canb
Posted: 12:16am 15 Nov 2012
That's an EXCELLENT workaround Jim.
Many thanks
James
Posted: 12:43am 15 Nov 2012
it is caused by the different environments.
In C# they solved it with a System.Environment.NewLine.
Maybe something that can be done with a #define in C too.
