Local Time 07:22 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit update
Posted: 09:04pm 10 Nov 2012
Just a small update.
The fix for V4.0 XMODEM bug now only appears if you are running V4.0
On all other versions, the checkbox does not appear.
You should upgrade MM Basic to V4.0B because my quick fix does not work on all files.
You can download the complete MM Edit program as usual or, if you are running 3.1 or later of MMEdit, extract the tkn file from the attached ZIP and place it in your MMEdit program folder.
2012-11-11_070042_MMedit.zip
