Local Time 12:16 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multiple 1-Wire devices on same bus?
ThierryP
Posted: 05:38am 02 Nov 2012
Is it possible to read sensor values from more than one 1-wire devices (DS18B20) on the same bus? Has anyone done that?
In http://www.thebackshed.com/forum/forum_posts.asp?TID=4741&KW =Onewire there's example code and Iandaus suggests/mentions that this is possible? How?
Thierry
Posted: 12:51pm 02 Nov 2012
Er... this is a good time to read about 1-wire and google's really good for finding stuff :)
It matters how you power them but do some reading and see.
ThierryP
Posted: 02:14pm 02 Nov 2012
Oh, I did google on this and indeed found that it is possible and how to wire that.
Problem is that I have not found ways of addressing multiple devices with MMBasic, other than searching for them and finding that they are connected on the 1-wire bus.
Sorry, perhaps I should have clearly stated that I wanted to do this in MMBasic.
Thierry
CircuitGizmos
Posted: 04:02pm 02 Nov 2012
I haven't tested 1-wire devices on the Maximite, although I am very familiar with them.
OWWRITE lets you select a Maximite pin and send data down that pin. If there is only a single 1-wire device on that line, then you don't need to specifically address that device using the device serial number. If there are multiple devices on that line, then to select a specific device you have to address that device using the device serial number.
' Reset device (flag = 1) on pin 3
' Write 2 bytes "SkipRom" (&hCC) and "Read Scratchpad" (&HBE)
OWWRITE 3, 1, 2, &HCC, &HBE
' DS18B20 read 2 bytes of temperature
OWREAD 3, 0, 2, byte1, byte2
This single device example is from memory, so I hope I get it right.
For multiple devices either you have to search to get the serial numbers for all of the devices on the Maximite pin, or do what I do and temporarily hook them to one pin to get their serial numbers. Then hardcode the serial numbers for each device when they are all on one Maximite pin.
Check out the 1-wire documentation for your specific device for the commands that you would use INSTEAD of the 'skip ROM' command to address a device by serial number.
You do specifically read them 1 device at a time. Each one uniquely addressed by their own serial number.
Edited by CircuitGizmos 2012-11-04
jman
Posted: 07:01pm 02 Nov 2012
hi
Are you short of I/O pins ?
If not why not use another pin with the next 1wire device on it.
ThierryP
Posted: 01:15pm 03 Nov 2012
I've done as advised and now have 3x DS1820 devices connected on same 1-Wire bus with one 4k7 pull-up resistor to Vcc=3.3V. No long wires yet, will add ~3m wires between MCU and each of the devices.
Following program is written in MMBasic 4.0 for Maximite, Duinomite, ... :
'Based on 1WDS1820.BAS 29 March 2012b by Ian Deney
'Example for three DS18X20 devices on the same 1-wire bus
'can be extended to larger number of Devices
'powered mode only
'Devices ID's are hardcoded
'MMBAsic 4.0
'ThierryP 03 November 2012
Pin=18
Dim ar(3,8)
'---Device 0 is a DS18B20:
ar(0,0)=40 : ar(0,1)=15 : ar(0,2)=8 : ar(0,3)=81
ar(0,4)=3 : ar(0,5)=0 : ar(0,6)=0 : ar(0,7)=183
'---Device 1 is a DS18S20:
ar(1,0)=16 : ar(1,1)=215: ar(1,2)=22: ar(1,3)=84
ar(1,4)=2 : ar(1,5)=8 : ar(1,6)=0 : ar(1,7)=181
'---Device 2 is a DS18S20:
ar(2,0)=16 : ar(2,1)=146: ar(2,2)=148: ar(2,3)=83
ar(2,4)=2 : ar(2,5)=8 : ar(2,6)=0 : ar(2,7)=229
main:
OWReset Pin,presence ' reset
If presence = 0 Then Error "No devices found"
For Dev=0 To 2
OWReset Pin
' start conversion
OWWrite Pin,8,9,&h55,ar(Dev,0),ar(Dev,1),ar(Dev,2),ar(Dev,3),ar(Dev, 4),ar(Dev,5),ar(Dev,6),ar(Dev,7)
OWWrite Pin,0,1,&h44
t = Timer
' wait until conversion is done
If Timer - t > 1000 Then Error "Sensor not responding"
OWRead Pin, 4 , 1 , b ' conversion done?
Loop Until b = 1
'read temperature from scratchpad and convert to degrees C + or -
' command read data
OWWrite Pin,1,9,&h55,ar(Dev,0),ar(Dev,1),ar(Dev,2),ar(Dev,3),ar(Dev, 4),ar(Dev,5),ar(Dev,6),ar(Dev,7)
OWWrite Pin,0,1,&hbe
OWRead Pin, 2, 2, T1, T2 ' get the data
OWReset Pin
' calculate temp depending on device in use
If ar(Dev,0)=40 Then 'DS18S22 or DS18B20 is 12 bit
If T2 And &b1000 Then 'negative temp
'make 2s complement (1s complement+1)
T2 = (T2 Xor &b11111111)
T1 = (T1 Xor &b11111111)+1
If T1=1 Then T2=T2+1 'add the carry if required
Value = ((T2 And &b111) * 256 + T1) / 16
Value = -Value
Else 'positive temp
ElseIf ar(Dev,0)=16 Then 'DS18S20 or DS1820 is 9bit or calc to 12bit
If T2 And &b10000000 Then 'if MSB of T2=1 then negative
'Read 12bit resolution and adjust
'read scratchpad using matchrom to get Count Remaining @byte 7
OWRead Pin,0,8,a,b,c,d,e,f,g,h
COUNTREM=g
'truncate 0.5deg value (or use integer division \)
T1t = T1 And &b11111110
T1t=T1t / 2 'make whole degrees
'add compensation values read from scratchpad
T1t16=T1t*16 'make lsb 1/16 degree
Value12 = T1t16 -4 +(16 - COUNTREM) 'add 12 bit value
'take 2s complement
T1C = (Value12 Xor &b11111111111) + 1
Value = T1C/16 'make decimal value in degrees
Value = -Value
Else 'positive temp
Value = T1 / 2 '9bit value
COUNTREM=g
T1t = T1 And &b11111110 'truncate 0.5deg(or use integer division \)
Value = T1t/2
Value = Value - 0.25 + (16 - COUNTREM) /16 '12 bit value
Print "Device:"; Dev; " type:"; ar(Dev,0); " Temp:" ; Format$(Value,"% 1.2f")
Next Dev
Print "------------------------------"
Pause 10000
GoTo main
Thierry
Blackened
Posted: 07:46pm 19 Jul 2013
Forgive me for asking what is possibly obvious for you guys. I've used the previous piece of code in my current project. I'm going through it a line at a time as I have struggled to get my head fully around the whole 1-wire and DS18B20 saga
I've changed it a bit so far, getting rid of the array for sensor IDs and using DATA:READ. So far so good.
My question is..... can the hex constants be used in the following manner:
match_rom = &h55
OWWrite Pin,8,9,match_rom,aa,bb,cc,dd,ee,ff,gg,hh
I'm assuming so, but this stuff fries my brain. I wish I did this sort of thing for a living hey.
Also, what are the differences between the various flavours of DS18x20 sensors? I intend to optimise the code as I only use the 18B version (and only have the 18B datasheet) and don't need to test for other types.
Thanks everyone
  ThierryP said   I've done as advised and now have 3x DS1820 devices connected on same 1-Wire bus with one 4k7 pull-up resistor to Vcc=3.3V. No long wires yet, will add ~3m wires between MCU and each of the devices.
'powered mode only
'MMBAsic 4.0
'snip
Thierry
Posted: 08:27pm 19 Jul 2013
Using match_rom should be OK.
Sorry, I've only used the B variant (not from MMBasic) so can't help with the variants.
Blackened
Posted: 04:59am 21 Jul 2013
I've been messing around with the 1-wire DS18B20 temperature sensors and have come up with the following code that suits my particular application better than the generic code that has been posted on the forum. This is more suitable for multiple sensors on a single bus, the more sensors, the more time will be saved if all devices are instructed to perform a conversion simultaneously. The only drawback that I see is that you can't test for completion, only wait the maximum time (plus a little longer).
This is tested and is working on my setup. If anyone else tries it and finds a problem please let me know
Interestingly, replacing the hex constants with easier (IMHO) to follow variable names worked perfectly with the exception of &hbe scratchpad read. I got the error "Variable not a one dimensional numeric array or a string". Thoughts anyone?
I hope someone finds this useful.
'Peter Angus July 2013
'Temperature conversion formula hacked version from ThierryP 03 November 2012
'Get temperature from multiple ds18b20 sensors
'externally powered on a single bus
'12bit accuracy but conversion is done in parallel
'to speed up reading all sensors.
'reduced accuracy will further improve response time
bus_pin = 1
active = 0
skip_rom = &hcc
convert = &h44
sensors = 3
dim temp(1,sensors) 'retain all temperatures after reading
'Sensor data for testing
data 40,15,51,172,4,0,0,213
data 40,166,121,172,4,0,0,75
data 40,120,35,172,4,0,0,180
owreset bus_pin,active
if active = 1 then
owwrite bus_pin,1,2,skip_rom,convert
pause 800 'ensure all sensors have performed a conversion
for i = 0 to (sensors-1)
read a,b,c,d,e,f,g,h 'get the sensor ID fields
temp(0,i) = DS18B20_readtemp(bus_pin,a,b,c,d,e,f,g,h)
print "sensor #" i " = " temp(0,i)
next i
endif
restore
end
'read the temperature from a specified DS18B20
'inputs are pin number of 1-wire signal bus, and 8 ID inputs
'devices must have already been instructed to perform a conversion
function DS18B20_readtemp (aPin,aa,bb,cc,dd,ee,ff,gg,hh)
Local T1,T2,temp
local match_rom
match_rom = &h55
OWWrite aPin,1,9,match_rom,aa,bb,cc,dd,ee,ff,gg,hh 'write a match rom request
OWWrite aPin,0,1,&hbe 'instruct a scratchpad read
OWRead aPin, 2, 2, T1, T2 'read the scratchpad data
temp = ((T2 And &b111) * 256 + T1) / 16
temp = -temp
Else 'positive temp
DS18B20_readtemp = temp
End function
