Local Time 07:21 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card Problem
     Page 1 of 3
cosmic frog
Posted: 07:37am 19 Oct 2012
Hi, just built my colour Maximite using a UBW32 which was previously a monochrome Maximite using MMBASIC 3.2. Done all the re-wiring, flashed it with MMBASIC 4.0. works great except for the memory card, it just says "cannot access the SD card".
I've checked and re-checked all the wiring and all looks good. The SD card isn't in a socket but solded staight to wires and then to the UBW32 board, so not a socket problem. I've noticed the use of a 2.2ohm resistor on the 3.3volt line which wasn't present on the monchrome Maximite, is it possible that not enough power is going to the SD card?
I hope someone can help.
Thanks. Dave.
cosmic frog
Posted: 07:43am 19 Oct 2012
Also I've noticed the curser sometimes doesn't appear!
cosmic frog
Posted: 08:18am 19 Oct 2012
Sorted. Bypassed the 2.2ohm resistor and all works well.
Thanks. Dave.
donmck
Posted: 10:46am 19 Oct 2012
  cosmic frog said   Sorted. Bypassed the 2.2ohm resistor and all works well.
Thanks. Dave.
Mick designed the UBW32-MCC-PCB:
http://www.dontronics-shop.com/ubw32-mcc-pcb-letter.html
and obviously noted the differences and tested it both ways:
See R12 near the SD card. He has it shorted out.
I spoke to him this morning about it. His response:
I also ran with it shorted as can be seen in the actual picture R12 just above the power jack.
So I don't think its critical.
Don...Edited by donmck 2012-10-20
https://www.dontronics.com
cosmic frog
Posted: 11:43am 19 Oct 2012
Thanks for that Don, It's good to have this confirmed. I was a little worried that I'd blown something.
Dave.
Zougie
Posted: 02:08am 23 Oct 2012
Hi Guys, I have exactly the same issue on two UBW32 MCC's which has not been rectified by shorting out R12 and am now beginning to suspect a possible issue with the fact that I used the UBW32 bootloader to load the Colour MMbasic V4.0. Both MCC`s fire up but the SD card cannot be found.
Has anyone else had this very same issue? If so, which version of the Maximite bootloader would be most preferable. By the way, I did try flashing the V4.0 software with the bootloader into the UBW32 using a Pickit3, but it would not fire up once programmed which is why I went back to the UBW32 bootloader.
Looking forward to some of your thoughts.
Cheers, GeorgeEdited by Zougie 2012-10-24
Posted: 02:44am 23 Oct 2012
I programmed it with the bootloader that is included in the mmbasic zip fie. That worked good.
Posted: 09:43am 23 Oct 2012
  Zougie said   MCC`s fire up but the SD card cannot be found.
Gday George,
I think you may not have flashed in the correct bootloader for the CMM. Use the Hex file that is included here CMM Construction Pack as that includes the bootloader with the HEX file (needs a PicKit3 to program it into the UBW32)
As to your problem, the UBW bootloader shouldnt make any difference, have you tried different brands of SD card? Check that you dont have solder shorts or an unsoldered pin on your SD connector.
regards,
Zougie
Posted: 03:54pm 23 Oct 2012
G'Day Guys, I did initially try flashing the file "ColourMM_plus_bootloader_V4.0.hex"
into the UBW32 using a Pickit3 and MPLAB 8.x ....but it did not come to life when powered up. After many attempts at programming the PIC, I decided to try the native UBW32 bootloader which then allowed me to load the ColourMM V4.0 file.
This then raises the question of what I was doing wrong in MPLAB? Any thoughts?
Mick you made a good point regarding potential soldering issues on the SD card socket, I'll have another check....but you certainly were not joking about how difficult these are to solder!!! Overall, the board has come together very nicely thanks to your efforts.
Cheers,
George
Posted: 10:34pm 23 Oct 2012
Cheers,
George
Hi George,
Are you referring to my UBW32-MCC PCB? If so then I believe your problem might be with the soldering associated with the G3 and G4 pads on the microSD socket.
You can test the function of the switch (G3 and G4) by using a meter to measure between GND and the pads for D5 and D6 of the UBW32 connector (see layout below). With a microSD inserted you should see GND appear at D5 and D6.
If you dont get a GND connection on D5 and D6 (pins on the UBW32) then MMbasic will not detect the SD card at all..
You could prove this by shorting D5/D6 to GND and seeing if you can read the SD card then.
The Pad for G3 is extremely hard to solder so I soldered it to the case first (the case is GND and the Pad should connect to GND so it makes it easier...
I have a fair bit in the manual about soldering the uSD socket... maybe you saw an earlier version of the manual... Get the latest one HERE
Kind Regards,
Posted: 10:38pm 23 Oct 2012
Sorry, I dont know how but I somehow duplicated my post..
Please ignore (or Gizmo please delete this post)
MickEdited by bigmik 2012-10-25
Zougie
Posted: 01:03am 24 Oct 2012
Hey Mick, I had a look at my soldering (via a USB camera/microscope) on all of the rearwood connector pins (1-8) and they all looked good......but the G3 and G4 pins from memory have been missed entirely.....my bad! Now I have to lovingly pry off the outer housing of the micro SD slot and risk doing more harm, or just tell the ubw32-mcc that there's a card in place by simply shorting d5/d6 to gnd and leaving it at that.
I'll give a go tomorrow evening and let you know if it's a success.
Thanks again for some excellent advice.
Cheers,
George
Posted: 09:50am 24 Oct 2012
  Zougie said   Hey Mick, I had a look at my soldering (via a USB camera/microscope) on all of the rearwood connector pins (1-8) and they all looked good......but the G3 and G4 pins from memory have been missed entirely.....my bad! Now I have to lovingly pry off the outer housing of the micro SD slot and risk doing more harm, or just tell the ubw32-mcc that there's a card in place by simply shorting d5/d6 to gnd and leaving it at that.
Hi George,
The G4 pad is easy enough to solder once the uSD socket is `in place' especially if you use some `liquid flux' paste... just coat the area and hit with a SHARP pointed iron that has some solder on the tip... In retrospect I wish I made the PADs a bit larger for G3 and G4 but I made the artwork exactly to the specs given by the manufacturer... no doubt for a SMD solder bath method...
The G3 pad is a bit harder to solder (if you didn't solder it to the case before fitting on the PCB).. If you have a VERY Sharp pointed iron is is possible but mine was a point but rounded at the end and I couldn't get in there.. I was able to solder my first one by flooding the area with flux and solder but that was a bit messy.
PS. I used a USB microscope as well to check the soldering for shorts/missed connections.
Zougie
Posted: 04:28am 26 Oct 2012
Hi Guys, Good news! I took Mick's advice and persisted with the soldering of the g3/g4 pads on the micro sd socket which was certainly tricky, but paid off! I managed to get both units up and running with full sd card access. Now for the fun part.
Thanks again for your excellent support!
Cheers,
George
Posted: 04:32am 26 Oct 2012
  Zougie said   Hi Guys, Good news! I took Mick's advice and persisted with the soldering of the g3/g4 pads on the micro sd socket which was certainly tricky, but paid off! I managed to get both units up and running with full sd card access. Now for the fun part.
Cheers,
George
Great News,
You are the first to report that you have got one working... (besides me of course)
Zougie
Posted: 12:06pm 26 Oct 2012
Mick, I'll now perform some tests on the i/o to make sure that all pins are accessable.
Cheers,
George.
Posted: 12:24pm 26 Oct 2012
  Zougie said   Mick, I'll now perform some tests on the i/o to make sure that all pins are accessable.
Cheers,
George.
Hi George,
You can always download TESTER3.BAS ..
It is currently configured only for GPIO 1-20 but is easy enough to modify for 21-40 to test the IO..
I used my Test-A-Mite to do the testing...
After the Melbourne Cup week is Over I intend to modify the program to include GPIO 21-40 as well.. but for now time has almost escaped me.
EDIT***
Of course depending on which way you have linked the JPX header the modifying the program will be easy or more dificult, if linked for `standard pattern' it will be easy, if linked for `Arduino pattern' it will be a bit all over the shop..
Mik
Edited by bigmik 2012-10-27
donmck
Posted: 12:44pm 26 Oct 2012
I can help a little here Mick.
I made up a 21 to 40 pin test program from your original, so I could produce a video.
Program is at:
http://tinyurl.com/8gahyc5
called testubw.bas I just loaded it there.
It is rough, as only 3 of the LED programs work. Just got it working enough to produce the video.
video is at:
http://www.youtube.com/watch?v=UV3U3g1YU4g&feature=youtu.be
Will be enough to test the outputs to LEDs.
Don...
Zougie
Posted: 02:26pm 26 Oct 2012
Sounds like a plan to me! I'll give it a go this weekend and will keep you posted. Thanks again for your help!
Cheers,
George
aargee
Posted: 10:02pm 26 Oct 2012
Mick,
Just finished the board and ran a quick test boots MM4 OK, keyboard OK, uSD OK. My UBW32 was hand assembled as well! I'll post some pics soon.
Thanks,
- Rob
     Page 1 of 3
