Local Time 09:49 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hooking DM to DealExtreme display module
jdh2550
Posted: 06:14pm 17 Oct 2012
File this one under "deal extreme success"
A while ago bigmik pointed out some interesting stuff on the dx.com site: what to do with our 'mites
I ordered 3 things one of which was this: 8x button, 8x LED, 8x 7-Segment Display Module It's only $7 and that includes free shipping!
I think it's probably a great addition for a lot of projects out there. I'm going to use mine for my Prius CAN based project because I don't want to use a full keyboard in the car. So, I've spent the last couple of evenings playing with this module and managed to start to get it working tonight.
In the end the code is actually pretty simple! The downside is that "out the box" when you power up the module there's no way to tell if it's a DOA unit (always a risk with DX). It took a little bit of playing around - but in the end it was actually simpler than I thought because this module is very forgiving with the clock signal. It was a relief to see the LEDs light up and to know that the unit works.
BTW, I also recently bought a low cost logic analyzer:
Open Bench Logic Sniffer (for $50 from Cute Digi). It was my first time playing with a logic analyzer and it was very helpful in figuring stuff out (because inserting print statements doesn't cut it for debugging this sort of stuff). I highly recommend this product!
Code is listed below (MMBasic V4) and hopefully it should be fairly readable. It's based on code from these two sources:
http://www.picaxeforum.co.uk/showthread.php?21006-Driving-JY -LKM1638-from-08M2
http://code.google.com/p/tm1638-library/ (mostly this link)
And the following page is a good overview:
http://tronixstuff.wordpress.com/2012/03/11/arduino-and-tm16 38-led-display-modules/
Only the LED code is implemented so far - but the rest is just a matter of porting over the rest of the software - which is the easy stuff for me. When I get that done I'll update this thread with the complete package.
Enjoy the blinky lights and if you look at the code and can think of a better way please let me know. (Especially the bitwise operation in TMSend)
p.s. I'm hoping that MMBasic 4+n will incorporate some form of "file include" directive to make distributing and using library code easier.
' MMBasic v4.0 Sample
' LIBRARY CODE for driving JY-MCU / JY-LKM1638 module availble from:
' http://dx.com/p/8x-digital-tube-8x-key-8x-double-color-led-m odule-81873
' Code copyright 2012 John Harding
' Beer License: if this is of any value to you and our paths should cross
' then buy me a beer.
' you can choose any three pins you want...
CLK = 13 : DIO = 14 : STB = 15
' Setup pins and initialize the module
Sub TMSetup
SetPin CLK,8 : SetPin DIO,8 : SetPin STB,8
Pin(STB)=1 : Pin(CLK)=1
TMSendCmd(&h40) : TMSendCmd(&h8F)
Pin(STB)=0
TMSend(&hC0)
Local i ' strange that I have to declare local i for this for/next to work
For i=0 To 15
TMSend(&h00) 'zero out everything
Next i
Pin(STB)=1
' Send one byte to the module
' note that this routine produces a clock signal with a "lop-sided" duty cycle
' however the module doesn't seem to care.
Sub TMSend(data)
j = 1
For i=0 To 7
Pin(CLK)=0
If (data And j) Then
Pin(DIO)=1
Else
Pin(DIO)=0
j = j * 2 ' this is an "expensive operation" is there a better way?
Pin(CLK)=1
Next i
' Send a command byte to the module
Sub TMSendCmd(cmd)
Pin(STB)=0
TMSend(cmd)
Pin(STB)=1
' Send a data byte to the module
Sub TMSendData(address, data)
TMSendCmd(&h44)
Pin(STB)=0
TMSend(&hC0 Or address)
TMSend(data)
Pin(STB)=1
' Set the LED number (0 based) to the given color
' c=1 - red
' c=2 - green
' c=3 - red + green = orange
' c=any other value switches off LED
Sub TMSetLED(p, c)
TMSendData( p*2+1, c )
' DEMO code for the above library...
TMSetup()
Cls
? "watch the pretty lights and press q when bored"
led = 0
clr = 1
If (Inkey$="q") Then End
TMSetLED(led, clr)
? @(0,20) "led " led " set to color (or colour) " clr
Pause(200)
led = led + 1 : If led > 7 Then led = 0
If led = 0 Then
clr = clr + 1 : If clr > 3 Then clr = 0
Posted: 09:01pm 17 Oct 2012
Hi JDH,
Great I think you might have saved me a lot of heart ache..
I haven't got a lot of time to play with these things until after the Melbourne Cup due to severe work load.
But I await your efforts eagerly.
That logic analyser looks good too..
I have read that the PicKit 3 can function as a logic analyser as well has anyone used this? And can comment on its usefullness?
jdh2550
Posted: 05:33am 18 Oct 2012
  bigmik said   Hi JDH,
Mick - I never realized you were a jockey!
WRT to the BT module - it will probably take a back seat for a while. I also noticed that DX.com carry several versions of this module - some pre-mounted on some form of carrier board. See this one as an example BT Serial Module on a carrier board. For the extra $5 it would probably suit me better to have it pre-mounted with the few extra components already taken care of - not to mention the fact that did I mention how bad I am at soldering?
WRT to the logic analyzer - I imagine a lot comes down to the software that you use to interact with it. The software for the OLS is open-source and could probably be adapted for the PicKit 3 if someone wanted to go that route.
Posted: 09:05am 18 Oct 2012
Yeah I am always on the `TOP WEIGHT'
Posted: 02:04am 19 Oct 2012
Great - and thanks for the URLs for those devices!
For this:
Sub TMSend(data)
j = 1
For i=0 To 7
Pin(CLK)=0
Pin(DIO)=1
Else
Pin(DIO)=0
Pin(CLK)=1
Next i
Maybe (but I can't test it!):
Sub TMSend(data)
For i=0 To 7
Pin(CLK)=0
Pin(DIO) = data And 1
data = data \ 2 ' still expensive (slow) - note \ is integer division
Pin(CLK)=1
Next i
Edited by JohnS 2012-10-20
jdh2550
Posted: 06:54am 19 Oct 2012
JohnS - thanks for that. Integer division should definitely be quicker than floating point multiplication!
I've actually switched to a lookup based approach:
[code]
Dim powersOf2(8)
powersOf2(0)=1 : powersOf2(1)=2 : powersOf2(2)=4 etc...
Sub TMSend(data)
For i=0 To 7
Pin(CLK)=0
Pin(DIO) = data And powersOf2(i)
Pin(CLK)=1
Next i
[/code]
I'll look at the waveform produced with all three methods.
jdh2550
Posted: 04:59pm 19 Oct 2012
OK, I've added code for the 8 character 7-segment display but it's not working.
I've also added code to read the buttons - and that does work.
I actually only want the LEDs and buttons for my project so debugging the 7-segment display routines is left as an exercise for the reader!
[code]
' Naming convention:
' - all library functions start with tm or TM
' - tm functions are part of the "internals" and aren't intended to be called
' - TM functions are the ones which you will use in your code
' - TM functions are listed first, tm ones second
' Demo code is at the bottom of this file - you don't need to copy that
' into your code.
' Initialization
Sub TMSetup
tmSendCmd(&h40) ' auto-address mode
tmSendCmd(&h8F) ' max brightness
Pin(STB)=0
tmSend(&hC0) ' start address
Local i
For i=0 To 15
tmSend(&h00) 'zero out everything
Next i
Pin(STB)=1
' LED commands
' c=1 - red
' c=2 - green
Sub TMSetLED(p, c)
tmSendData( p*2+1, c )
' Button commands
' read the state of the buttons
Function TMGetButtons
Local a, b, c, d
Pin(STB)=0
tmSend(&h42)
a = tmReceive()
b = tmReceive()
c = tmReceive()
d = tmReceive()
Pin(STB)=1
TMGetButtons = 0
If (a And 1) Then TMGetButtons = TMGetButtons Or p2(0)
If (b And 1) Then TMGetButtons = TMGetButtons Or p2(1)
If (c And 1) Then TMGetButtons = TMGetButtons Or p2(2)
If (d And 1) Then TMGetButtons = TMGetButtons Or p2(3)
If (a And 16) Then TMGetButtons = TMGetButtons Or p2(4)
If (b And 16) Then TMGetButtons = TMGetButtons Or p2(5)
If (c And 16) Then TMGetButtons = TMGetButtons Or p2(6)
If (d And 16) Then TMGetButtons = TMGetButtons Or p2(7)
End Function
' 7-Segment Display commands
' NOT WORKING :-(
' Turn on the display with a given brightness
Sub TMSetupDisplay(active, intensity)
If (intensity > 7) Then intensity = 7
If (active <> 0) Then active = 8
tmSendCmd(&h80 Or active Or intensity)
Pin(STB)=0
Pin(CLK)=0
Pin(CLK)=1
Pin(STB)=1
' Clear a segment
Sub TMClearDisplayDigit(p, dot)
tmSendChar(p, 0, dot)
' Send string s$ to the display
' dots is a byte of flags for each of the 8 available dots
Sub TMSetDisplay(s$,dots)
n = Len(s$)
If n>8 Then n=8
Local i
For i=1 To n
? i " ";
tmSendChar(p2(i), Mid$(s$,i,1),dots And p2(i-1))
Next i
' clear entire display
Sub TMClearDisplay()
For i=0 To 7
tmSendData(i*2,0)
Next i
' send character c$ to segment p and light the dot if dot<>0
Sub TMSendChar(p, c$, dot)
? "p = " p " c$ = " c$ " dot = " dot " pattern = " Bin$(tmGetSegPat(c$, dot))
tmSendData(p*2, tmGetSegPat(c$, dot))
' Private code (internal workings of library - you won't use these directly)
' 7 segment display representation of ASCII chars from space (32) to Z (90)
Data 0,&b10000110,&b00100010,&b01111110,&b01101101,0,0,&b00000010
Data &b00110000,&b00000110,&b01100011,0,&b00000100,&b01000000,&b1 0000000
Data &b01010010,&b00111111,&b00000110,&b01011011,&b01001111,&b011 00110
Data &b01101101,&b01111101,&b00100111,&b01111111,&b01101111,0,0,0
Data &b01001000,0,&b01010011,&b01011111,&b01110111,&b01111111,&b0 0111001
Data &b00111111,&b01111001,&b01110001,&b00111101,&b01110110,&b000 00110
Data &b00011111,&b01101001,&b00111000,&b00010101,&b00110111,&b001 11111
Data &b01110011,&b01100111,&b00110001,&b01101101,&b01111000,&b001 11110
Data &b00101010,&b00011101,&b01110110,&b01101110,&b01011011
Dim p2(8)
p2(0)=1:p2(1)=2:p2(2)=4:p2(3)=8:p2(4)=16:p2(5)=32:p2(6)=64:p 2(7)=128
Dim tmSegPat(59)
For i=0 To 58
Read tmSegPat(i)
Next i
Function tmGetSegPat(c$, dot)
i=Asc(c$)-32
If (i<0) Then i=0
If (i>58) Then i=58
tmGetSegPat=tmSegPat(i)
If (dot<>0) Then tmGetSegPat = tmGetSegPat Or 128
End Function
Sub tmSendCmd(cmd)
Pin(STB)=0
TMSend(cmd)
Pin(STB)=1
Sub tmSendData(address, data)
TMSendCmd(&h44)
Pin(STB)=0
TMSend(data)
Pin(STB)=1
Sub tmSend(data)
Local i
For i=0 To 7
Pin(CLK)=0
If (data And p2(i)) Then
Pin(DIO)=1
Else
Pin(DIO)=0
Pin(CLK)=1
Next i
Function tmReceive
tmReceive = 0
SetPin DIO,2 ' set pin as input
Local i
For i=0 To 7
tmReceive = tmReceive \ 2
Pin(CLK)=0
If (Pin(DIO)=1) Then tmReceive = tmReceive Or &h80
Pin(CLK)=1
Next i
SetPin DIO,8 ' set pin back to output
End Function
TMSetup()
TMSetupDisplay(1,7)
TMSetLED(0,1)
TMSetDisplay("12345678",255)
TMSendChar(128,"1",1)
Cls
? "watch the pretty lights and press b when bored"
led = 0
clr = 1
If (Inkey$="b") Then Exit
TMSetLED(led, clr)
Pause(200)
If led = 0 Then
Sub setLedFromButton(buttons, b)
If (buttons And p2(b)) Then
TMSetLED(b, 1)
Else
TMSetLED(b, 0)
Cls
? "now you can entertain yourself with buttons (and then b when bored)"
buttons=0
buttons = TMGetButtons()
? @(0,20) " "
? @(0,20) "buttons = " Bin$(buttons+256)
For i=0 To 7
setLedFromButton(buttons, i)
Next i
[/code]
Posted: 03:32am 20 Oct 2012
  jdh2550 said   JohnS - thanks for that. Integer division should definitely be quicker than floating point multiplication!
[code]
Dim powersOf2(8)
Sub TMSend(data)
For i=0 To 7
Pin(CLK)=0
Pin(CLK)=1
Next i
[/code]
That would not have worked, because your original wanted to output either a 1 or 0 and the above doesn't, but I see you fixed it in the longer post above.
Ray B
Posted: 02:15am 31 Oct 2012
Follow this link to interface to a picaxe fitted with a shield I/O pattern
http://www.picaxeforum.co.uk/showthread.php?21884-Interfacin g-the-low-cost-DX-LCD-Keypad-%28shield%29-with-the-PICAXE-AX E401-Shield
Enjoy
RayB from Perth WA
James_From_Canb
Posted: 12:43pm 31 Oct 2012
[code]
Dim powersOf2(8)
Sub TMSend(data)
For i=0 To 7
Pin(CLK)=0
Pin(CLK)=1
Next i
[/code]
It may look like it will not work, but it uses the same technique that Geoff used in his demo LCD code. If the entire variable is zero the pin is set to zero; if the variable is non-zero the pin is set to 1.
James
Posted: 09:34pm 31 Oct 2012
You're right! Sorry.
Posted: 02:34am 19 Apr 2013
Hi Fellas,
I am not really sure I want to post this now as it will expose me for the inept programmer that I am...
I should have looked at this thread for followups as I used Johns original code as a base for my fiddling.
Now I will explain that I am not really comfortable with No line Numbers and Do-Loops but I did this as a bit of an experiment and I am getting my head around it all.. I cannot cope with all the high level maths posted above but I did modify Johns Original and get the 7Segs working... If anyone is interested in looking at it please be my guest..
2013-04-19_122352_7SEG.zip
Please dont laugh at me, I am a silly old bugger that has drunk too much of Dons beer in my time...
I tried to get the buttons working but as I cant understand C I struggled and failed miserably.. So I will look at Johns later posting for help in that area..
Anyway I am interested in seeing this library completed so I have exposed my shame and posted my measly effort here for all to see.
