Local Time 06:54 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Vacuum Fluorescent Display test
CircuitGizmos
Posted: 06:45am 06 Oct 2012
I've had a couple of these display modules setting around for a while. They have a 10-pin connector, not the 'normal' 14 that an LCD module has. I also don't have a data sheet for the display, but a couple of old data sheets for different displays. Every time I bump into the modules in my box of stuff I wonder what they look like when activated.
But it has always been a bother to try to figure out if any of the datasheets apply, if any do at all.
Today I decided to wire up the display to a CGMMSTICK to play around with them. It is a 5V display, so I used OC outputs pulled to 5V through a 10k resistor. The display has a reset line, data in, and clock. Data is most significant bit first.
Pins 2, 4, 6, 8, 10 are ground
Pin 1 +5V
Pin 3 clock
Pin 5 data
Pin 7 reset
The value that it takes to write "A" is 1, "B" is 2. This doesn't follow ASCII. Below is the code I used to test the display:
' VFD test code
' I/O init
' Open collector data
SETPIN 12, 9 : PIN(12) = 1
' Open collector clock
SETPIN 13, 9 : PIN(13) = 0
' Open collector reset
SETPIN 15, 9 : PIN(15) = 1
' Values for characters
_A = 1 : _B = 2 : _C = 3 : _D = 4 : _E = 5 : _F = 6 : _G = 7 : _H = 8 : _I = 9 : _J = 10
_K = 11 : _L = 12 : _M = 13 : _N = 14 : _O = 15 : _P = 16 : _Q = 17 : _R = 18 : _S = 19
_T = 20 : _U = 21 : _V = 22 : _W = 23 : _X = 24 : _Y = 25 : _Z = 26
_AT = 0 : _SPACE = 32
_ZERO = 48 : _ONE = 49 : _TWO = 50 : _THREE = 51 : _FOUR = 52 : _FIVE = 53
_SIX = 54 : _SEVEN = 55 : _EIGHT = 56 : _NINE = 57
' Initialize and send characters
' Reset and init LCD
VFDRESET
VFDDATA _SPACE
VFDDATA _T
VFDDATA _H
VFDDATA _E
VFDDATA _SPACE
VFDDATA _B
VFDDATA _A
VFDDATA _C
VFDDATA _K
VFDDATA _SPACE
VFDDATA _S
VFDDATA _H
VFDDATA _E
VFDDATA _D
VFDDATA _SPACE
END
' VFD display reset routine
Sub VFDRESET
' pulse the reset line
PIN(15) = 1 : PAUSE 1
PIN(15) = 0 : PAUSE 1
' Clear the display
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
VFDDATA &h20
' Turn display on
VFDDATA &hFF
' Write data to display, MSB first
Sub VFDDATA (valu)
PIN(13) = 1
PIN(12) = valu AND &B10000000
PIN(13) = 0 : PIN(13) = 1
PIN(12) = valu AND &B01000000
PIN(12) = valu AND &B00100000
PIN(12) = valu AND &B00010000
PIN(12) = valu AND &B00001000
PIN(12) = valu AND &B00000100
PIN(12) = valu AND &B00000010
PIN(12) = valu AND &B00000001
And the result:
I don't know if any displays like this one show up as surplus, but if they do, this test code will help get them working.
Edited by CircuitGizmos 2012-10-07
