Local Time 07:44 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : EasyPIC Fusion
vasi
Posted: 08:13pm 28 Aug 2012
Well, I said it few times - develop on PIC24 and burn the final application on PIC32.
Mikroelektronika did it:
Edited by vasi 2012-08-30
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 12:20am 29 Aug 2012
It's rather expensive!!
elproducts
Posted: 12:48am 29 Aug 2012
You could just use the Microchip Microstick II. It even comes with a PIC24F, PIC24H, dsPIC33 and PIC32 DIP and built in programmer/debugger. All for $35. Plugs right into a breadboard.
Wish these PIC32 DIPs had enough memory to run Maximite.
There are so many simple, small, easy to kit/build gadgets you could create with a Maximite DIP chip.
www.elproducts.com
Posted: 01:47am 29 Aug 2012
A PIC32MX130F064B should be able to run a modified MMBasic.
If you take out the video routines and maybe some other parts that are not usefull for a chip like that you might be able to get it in the 64KB flash.
It has 16Kb ram and according to the mmbasic.com website that should be the minimum to run mmbasic.
vasi
Posted: 08:05am 29 Aug 2012
Of course I don't have money for that board but if it is to be 100 pin PIC24/32 development board, then it has to be that board. No compromises.
For complex applications and for commercial applications this board is great.
For DIP packages I will rater stay with PIC18F/ATmega, at 5V, as I'm doing it already.
DuinoMiteMegaAn
Posted: 02:50pm 03 Sep 2012
The totaL cost for the Fusion v7 Pic Development "Kit" which includes the PIC32 micro adapter and software for only $440 USD. Too steep for my wallet.
One thing I did noticed is their top secret, advance technology "Mikro bus" which they said "covers 80% of interfacing requirements" A hacker could install an Olimex Arduino proto shield on top of the Color Maximite, add two 8 pin headers on the shield and use MikroElektronka's assorted 31 Click boards on the Color Maximite. The only unknown is whether SPI is available on the Arduino shield pins on the Color Maximite ??? Maybe GeoffG can chime in on this question.
BTW ... MikroBus Specs
2012-09-04_012039_mikrobus_specification.pdf
microSD click
ADC click
DIGI POT click
RS485 click 5V
MP3 Click
Buzz Click
RTC Click
RTC2 click
DAC Click
SHT11 click
EXPAND click
GPS Click
Bluetooth Click
ETH Click
BEE click
RS485 click 3.3V
LightHz click
CAN SPI click 3.3V
CAN SPI click 5V
GPS Click - L10
WiFi Plus Click
Accel click
IrDA2 click
OPTO click
THERMO click
Flash Click
EEPROM Click
7seg click
USB UART click
USB SPI click
4-20 mA T click
Edited by DuinoMiteMegaAn 2012-09-05
Posted: 07:44pm 03 Sep 2012
  DuinoMiteMegaAn said   The only unknown is whether SPI is available on the Arduino shield pins on the Color Maximite ???
Hi DMM,
I think that is what J2 and J3 is on the schematic are for...
SPI or I2C.
I havent been able to read the article yet as SC online still hasnt posted it....
(what a waste of $76)
MickEdited by bigmik 2012-09-05
Posted: 09:13pm 03 Sep 2012
From the Maximite hardware manual on Geoff's website:
Arduino Compatible I/O Connector
The Colour Maximite has an additional 20 I/O pins (40 in total) on the Arduino compatible connector. These
are independent of the I/O pins on the back panel.
The designation of the Arduino pins are printed on the PCB and follow the standard layout numbering D0 to
D13 and A0 to A5. You can use the labels D0, D1, etc in MMBasic statements or you can use their
corresponding numbers (D0 = 21, D1 = 22, etc and A0 = 35, A1 = 36, etc).
The digital pins (D0 to D13) have the same characteristics (5V, open collector, etc) as the digital pins 11 to 20
and the analog capable pins (A0 to A5) have the same capabilities as pins 1 to 10.
Many Arduino systems make the I2C available on connector pins A4 and A5. Using the jumpers (J2 and J3)
you can select between the normal I/O function for these pins (A4 and A5) or the I2C signals (SCL and SCA).
Note that these I2C signals are also available on the external I/O pins 12 and 13 on the back panel so effectively
these jumpers join these I/O pins together when in the I2C position.
No need to wait for SC.
DuinoMiteMegaAn
Posted: 03:05am 04 Sep 2012
Ok ... I2C is available on the Arduino header but is SPI (MOSI/MISO/SS) also
available? The DuinoMite Mega had the SPI (SD card) multiplexed on their Ardunio
pins which ended up being a total disaster.
Also, I like to mention that even though the MikoBus Click boards could be added
to the Color MaxiMite there could be other problems like pullups/pulldowns,
5v/3.3v logic and bus speed problems due to MMBasic speed. Edited by DuinoMiteMegaAn 2012-09-05
elproducts
Posted: 03:26am 04 Sep 2012
I haven't tried it but based on the MMBasic Language manual Appendix D, it appears that MMBasic is just bit-banging SPI so any set of digital pins will work.
The syntax of the function is:
received_data = SPI( rx, tx, clk, data_to_send, speed, mode, bits )
Data_to_send, speed, mode and bits are all optional. If not required they can be represented by either empty
space between the commas or left off the end of the list.
Where:
 ‘rx’ is the pin number for the data input (MISO)
 ‘tx’ is the pin number for the data output (MOSI)
 ‘clk’ is the pin number for the clock generated by MMBasic
To match the Arduino header setup:
SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK).
Try using this in MMBASIC:
received_data = SPI( D12, D11, D13, data_to_send, speed, mode, bits )
www.elproducts.com
DuinoMiteMegaAn
Posted: 03:44am 04 Sep 2012
So you are saying that the Color MaxiMite Arduino shield pins has software SPI and NOT a hardware SPI? Sounds reasonable but for driving other Arduino shields HW SPI is preferred. I believe the PIC32 has several hardware SPI buses (up to 4 SPI modules) available. Edited by DuinoMiteMegaAn 2012-09-05
paceman
Posted: 04:00am 04 Sep 2012
  DuinoMiteMegaAn said   So you are saying that the Color MaxiMite Arduino shield pins has software SPI and NOT a hardware SPI? Sounds reasonable but for driving other Arduino shields HW SPI is preferred. I believe the PIC32 has several hardware SPI buses (up to 4 SPI modules) available.
The Sept. Silicon Chip colour MM article (p24) explains it. The 64 pin PIC32 had 3 SPI outputs, the 100 pin PIC32 has 4 SPI outputs. In the colour MM though, 3 of the SPI's are needed to generate the colours and the 4th is still needed for the SD card. That leaves no hardware SPI's left, so bit-banging it is. On the plus side though, you get to choose which pins.
Greg
vasi
Posted: 08:21am 04 Sep 2012
  paceman said   ...and the 4th is still needed for the SD card.
Greg
Which is enough, in my opinion... It can be used as a bus for as many devices you can use. But I guess now is too late for the hardware design...
vasi
Posted: 11:34pm 07 Dec 2012
The other board from mikroe, used as "dock station" for mikromedia boards:
http://vimeo.com/44921142
So much elegance!
