Local Time 02:04 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Version of MMBasic. Version 3.2C
Posted: 04:59pm 09 Jun 2012
A new version of MMBasic (ver 3.2C) is available for download from http://geoffg.net/maximite.html#Downloads
This is a minor update that fixes a few bugs and adds two small features:
- Added support for control keys in the EDIT command and the command line editor.
- Added support for I/O pin 7 on the DuinoMite.
The Change Log (included in the update download) details the changes.
djuqa
Posted: 05:59pm 09 Jun 2012
Thanks .
MMbasic Just keeps getting BETTER.
VK4MU MicroController Units
donmck
Posted: 06:51pm 09 Jun 2012
  Geoffg said   A new version of MMBasic (ver 3.2C) is available for download from http://geoffg.net/maximite.html#Downloads
Geoff just told me that the latest version (3.2C) MMBasic now supports 15 pins on the DuinoMite, and not the 12 that I had advertised, so I have updated all of my product pages to suit.
Don...
https://www.dontronics.com
DuinoMiteMegaAn
Posted: 04:54am 10 Jun 2012
GeoffG - I made an easy to use Open Office (Free) spreadsheet for the MMBasic DuinoMiteMega GPIO for MMBasic 3.2C If you see any obvious mistakes - let me know.
2012-06-10_145401_MaxiMite_DuinoMiteMega_Input_Output_v3_2_C _R1.zip
BTW ... Can the comports (1-4) be used for other GPIO functions? eg input/output/interrupts
Edited by DuinoMiteMegaAn 2012-06-11
Posted: 11:49am 10 Jun 2012
  DuinoMiteMegaAn said  I made an easy to use Open Office (Free) spreadsheet for the MMBasic DuinoMiteMega GPIO for MMBasic 3.2C If you see any obvious mistakes - let me know.
Unfortunatly I cannot open this file. Can you save it as a Microsoft Excel (.xls) file?
  DuinoMiteMegaAn said  Can the comports (1-4) be used for other GPIO functions? eg input/output/interrupts
Yes, except for COM3:, details are in the DuinoMite ReadMe file included in the update.
BobD
Posted: 12:15pm 10 Jun 2012
MS Orifice 2010 handles it OK. I'll see if I can save it as an .xls and put it up here. If not I'll post it as an image.
BobD
Posted: 12:27pm 10 Jun 2012
Here is the image file 2012-06-10_222702_MaxiMite_DuinoMiteMega_Input_Output_v3_2_C _R1.pdf and here is the .xls 2012-06-10_222733_MaxiMite_DuinoMiteMega_Input_Output_v3_2_C _R1.zip
There was a complaint from excel about loss of features when saved to a compatibility format but I couldn't see the difference.Edited by BobD 2012-06-11
ajkw
Posted: 04:24pm 10 Jun 2012
Can somebody else with version 3.2C please test the following
print val("&B101")
or
print val("&HFF")
My MM with 3.2C throws an exception with these and reboots with the "An internal error.. " message.
Anthony.
BobDevries
Posted: 04:46pm 10 Jun 2012
Umm, without trying to be smart....
Why would you use that?
A simple:
PRINT &HFF
PRINT &B101
would suffice.
Edited by BobDevries 2012-06-12
Bob Devries
Dalby, QLD, Australia
ajkw
Posted: 04:59pm 10 Jun 2012
Bob,
Because I use the VAL function in a line of code which is too involved to use for practical debug purposes. This particular line of code worked fine in all previous versions but is now throwing the error in 3.2C
I posted PRINT VAL("&HFF") as quick way of checking for the error that can be done from the command line.
So, did you humour the seemingly strange ways of another user and try it??
Rgd's
Anthony.
Posted: 05:04pm 10 Jun 2012
That is a neat spreadsheet (and colourful).
The only changes that I would suggest are:
- pin 7 supports counting, frequency, period, etc.
- pins 11 & 12 support digital out on the Mini
- pins 7 & 11 to 18 support interrupts
Posted: 05:14pm 10 Jun 2012
I can confirm that bug Anthony.
Print val("&HFF") crashes the system.
Print val("1234") works fine.
Print &HFF works fine.
ajkw
Posted: 05:23pm 10 Jun 2012
Glenn,
Thanks for that, I guess it is over to Geoff to have a look.
Rgd's,
Anthony.
Posted: 06:15pm 10 Jun 2012
  ajkw said  print val("&HFF")
This is getting to be a bad habit... every time I make a new release a small bug appears. At least this one was not my fault. Microchip have managed to break the strtol() function in C32 V2.1a (which I recently upgraded to) and that caused the bug.
I have fixed it and loaded the new version up onto my site. It has the same version number (3.2C) but the date of the hex file is 11th June. So, if you have already downloaded 3.2C could you please re download and re flash.
Sorry for the inconvenience.
DuinoMiteMegaAn
Posted: 01:11am 11 Jun 2012
By inspecting the GPIO spreadsheet again ... if a user is using I2C, then the only GPIO pin that could be used for counting, frequency and period would ONLY be pin 7 (software#) on the DuinoMiteMega?
GeoffG .... Is counting, frequency and period a function of hardware or software ?
Posted: 02:41am 11 Jun 2012
It is hardware dependent. The PIC32 i/o pin must support an external interrupt.
