Local Time 01:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPI Comms
Gadget
Posted: 04:20am 10 May 2012
Has anyone tried to get to maximites (or variants of) to communicate with each other via SPI?
Terry
donmck
Posted: 08:32pm 11 May 2012
  Gadget said   Has anyone tried to get to maximites (or variants of) to communicate with each other via SPI?
Terry
Certainly been done with 232:
http://www.duinomite.com/serial-communication-between-two-du inomites-a-tutorial/
Cheers Don...
https://www.dontronics.com
Gadget
Posted: 01:49pm 12 May 2012
thanks Don,
I have seen that but RS232 is just a bit slow I was wanting higher speed comms as i have an idea that requires faster communications.
fyi i am experimenting with using one unit as normal with a second as a graphics processor.
Terry
graynomad
Posted: 03:44pm 18 May 2012
You can also use RS485 with a UART, can be as fast as SPI and good for long distances.
Are the two processors on the same PCB?
_____
RobEdited by graynomad 2012-05-20
Rob Gray, AKA the Graynomad, www.robgray.com
