Local Time 01:38 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Version of MMBasic. Version 3.2A
Posted: 06:30am 04 May 2012
A new version of MMBasic (ver 3.2A) is available for download from http://geoffg.net/maximite.html#Downloads
This is a minor update that fixes a few bugs mostly associated with drive A: and the serial ports on the DuinoMite. The Change Log (included in the update download) details the changes.
vk4tec
Posted: 11:10am 04 May 2012
Works for me
NMEA PARSE
LCD 20x4
SD card write
MOD-GPS
SETTICK
MATHS
USERBTN
All ok
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
donrecardo
Posted: 04:08pm 04 May 2012
  Geoffg said   A new version of MMBasic (ver 3.2A) is available for download from http://geoffg.net/maximite.html#Downloads
Hi Geoff
I, and another person I met both found a problem using MMBasic for dos .
If you set auto line numbering with
auto 10,10
it works fine , but when you want to end auto numbering and type "run" to try the code
there is a problem . CTRL C does not break you out of auto numbering.
I tried again using your new updated version of MMBasic but its still the same .
Is CTRL C the correct way to exit from auto line number or is it another key combination?
DonEdited by donrecardo 2012-05-06
vk4tec
Posted: 12:40am 05 May 2012
Andrew Rich VK4TEC
Posted: 01:31am 05 May 2012
  donrecardo said  I, and another person I met both found a problem using MMBasic for dos. If you set auto line numbering with auto 10,10 it works fine, but when you want to end auto numbering and type "run" to try the code there is a problem. CTRL C does not break you out of auto numbering.
Ah, that was a small bug in the DOS version only. I have fixed it now so please download the DOS version again and CTRL-C should work OK.
donmck
Posted: 04:19am 05 May 2012
  vk4tec said
Thanks very much Andrew, hAVE ADDED IT TO:
http://www.dontronics-shop.com/maximite-12pin-dm-mini.html
Cheers Don...
https://www.dontronics.com
donrecardo
Posted: 09:09am 05 May 2012
Thanks Geoff
It works fine now
Don
vk4tec
Posted: 08:44am 08 May 2012
Running MMBasic V3_2A in new DuinoMite Mega
Dropped in SD card - power up
Flashed
Works fine
- Andrew -
Andrew Rich VK4TEC
