Forum Index : Microcontroller and PC projects : non-standard baud rates
marcwolf
Posted: 06:22am 29 Apr 2012
I have a project in mind.. My car is a Commodore VS Series II Equipe (1996) with A 3.8L Ecotec engine in it.
Now this system uses a ALDL 8192 diagnostic system that one can tap into and get lots of interesting details about the car's normal running. Prob is that the interface uses 8192 baud and I am curious how I can get the Maximite to read this.
Any suggestions.
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
vk4tec
Posted: 06:34am 29 Apr 2012
When I was using PIC chips in stand alone mode, I would get the baud rate divider values and work it back to the crystal freq
You could put a different rock on board.
Although that will also modify the CPU speed.
Can you bit bang ?
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
Posted: 01:54pm 29 Apr 2012
Ver 3.1A (due out in a week or two) will support non standard baudrates on the DuinoMite hardware UARTs.
loki
Posted: 12:12am 02 May 2012
Can a baud rate of 31250 be achieved on the Maximite?
If so that would open up the world of MIDI & music to all.
I think Duinomite can do this baud rate?
rob
ernie
Posted: 07:58am 02 May 2012
  loki said   Can a baud rate of 31250 be achieved on the Maximite?
rob
The Duinomite will on Uart2 or Uart5
