Local Time 01:37 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MAX7219 LED display
vk4tec
Posted: 03:29pm 27 Apr 2012
Hello
I wonder if anytone has used a MAX7219 based LED display ?
It appears to have CLK LOAD DIN
The datasheet says it uses SPI - can the DuinoMite do SPI ?
Looks like a 16 bit number is to be clocked in.
Looks like LOAD is then set.
DIN data is loaded 16 bits on clk rising edge.
This one is 7-segment 8 digit
LOAD must be LOW to clock data into the chip.
The 16 bit number consists of
D15 - D12 ( not used )
D11 - D08 ( Address )
D07 - D00 ( Data MSB - LSB )
Seems quite simple
Need to send 16 bit numbers using clock, then set LOAD to HIGH
INIT
0A08 - Set Intensity middle
0B07 - Scan Limit ( 8 digits )
0900 - No decode BCD
0C01 - No shutdown
0F00 - No display test
Send each DIGIT 1,2,3,4,5,6,7,8
0000 0001 0000 0001 ( Address = 1, data = 1 )
0000 0010 0000 0010 ( Address = 2, data = 2 )
0000 0011 0000 0011 ( Address = 1, data = 3 )
etc
10 MHz serial interface
- Andrew - Edited by vk4tec 2012-04-29
Andrew Rich VK4TEC
www.tech-software.net
vk4tec
Posted: 05:02pm 27 Apr 2012
Is there any issues with the PIC32 only being able to drive 3.3 Volts on the SPI ?
Some devices might need above 3.3 VOLTS ?
- Andrew -
Andrew Rich VK4TEC
Posted: 05:18pm 27 Apr 2012
The target (slave) device data sheet should detail its voltage needs. If its supply voltage is up to about 3.6V all should be OK. If it's a 5V device, you could be needing level shifters.
vk4tec
Posted: 05:30pm 27 Apr 2012
Am I barking up the wrong tree here ?
Is SPI ONLY available on UEXT on a DuinoMite MINI ?
I am trying to assign SPI to the 26 way connector
Because MOD-GPS is already on the UEXT
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 06:04pm 27 Apr 2012
Fixed
I have SPI on 26 way connector
SETPIN 16,2 RX
SETPIN 17,8 TX
SETPIN 18,8 CLK ( Low Speed = L)
do
a = SPI(16,17,18,&HAA,L)
loop
Andrew Rich VK4TEC
