Forum Index : Microcontroller and PC projects : Button INT and timer
vk4tec
Posted: 12:59pm 27 Apr 2012
Hello
I am working on a GPS project
At the moment I am looking for a button press when the NMEA sentences are rolling past.
What I would like to do is make the button trigger an interupt, and simply increment a number.
Can someone help me understand the logic and some code to handle a button interrupt.
Also is there a way to run a tick timer in MMbasic ? like a master loop ?
At the moment when there is no GPS nothing happens.
My code is relying on the GPS coming in to do things.
Is there such a thing as a time out timer ?
How would you hand the lack of serial data ?
I would like to say "GPS DATA ERROR"
Maybe I can check the Serial Buffer ?
Best way to handle "NO COMM" situation ?
- Andrew -
Edited by vk4tec 2012-04-28
Andrew Rich VK4TEC
www.tech-software.net
vk4tec
Posted: 01:09pm 27 Apr 2012
I tried
SETTICK 500, screen
screen:
printlcd 1, "data"
IRETURN
"Error: Return from interrupt when not in an interupt"
Andrew Rich VK4TEC
vk4tec
Posted: 01:26pm 27 Apr 2012
Interseting
SETTICK 100, screen
Does not allow enough breathing space for the NMEA parse to happen.
SETTICK 500 does.
- Andrew -
Andrew Rich VK4TEC
James_From_Canb
Posted: 12:20am 28 Apr 2012
The "interrupt return" error is because your code sets the interrupt then processes the next instructions. When it reaches the IRETURN it gives the error message because it wasn't called by an interrupt.
You need a block of code before the screen label that ensures the screen routine is only called by an interrupt. For example, an endless loop.
James
  vk4tec said   I tried
SETTICK 500, screen
screen:
printlcd 1, "data"
IRETURN
vk4tec
Posted: 12:42am 28 Apr 2012
Thanks James
I moved the code outside the LOOP
Works fine
Andrew Rich VK4TEC
