Forum Index : Microcontroller and PC projects : Problem with MMBASIC (DOS)
BobDevries
Posted: 12:31am 26 Apr 2012
Hi all,
I've been trying out MMBASIC for DOS, and finding a few problems.
It frequently just quits if I type a line number by itself, to kill an existing line, or if I type NEW, to remove the programme in memory.
Anyone else seen this?
Bob Devries
Dalby, QLD, Australia
Posted: 07:44am 26 Apr 2012
I haven't seen your problems but I usually code in MM Edit and run the program once in DOS MM Basic.
I did try to get your errors but 20 or so NEW's worked OK and a similar number of line number entries also worked without fault.
I did find another problem:
The enter key on the number-pad does not work.
The number keys are OK but not the enter key.
