Local Time 01:38 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Gps Hardware and other Questions
plasma
Posted: 04:21am 19 Apr 2012
hi,
1 . can anyone recommend a Gps Hardware for the Maximite ?
2. why have Composite not the same Resolution as VGA ?
Have anyone changed the composite Resolution in the source ?
thx
Posted: 06:46am 19 Apr 2012
Any serial GPS that outputs the standard NMEA sentences should do.
Composite has to match the number of lines that the monitor expects so the resolution was set by the composite standard PAL or NTSC.
VGA is also a standard and it is unfortunate that they are different but thats the way it is.
You probably could change the bit rate to get a different number of pixels per line but that would upset the aspect ratio too much.
