Local Time 01:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit update
Posted: 02:54am 19 Apr 2012
Just a small update to MM Edit.
You can now run your code in DOS MMbasic directly from MM Edit.
The first time you try, it will ask for the location of MMBasic.exe
MM Edit then creates a temp.bas file and runs it in MMBasic.
There were no other changes needed to MM Edit for the new release of MM Basic.
CircuitGizmos
Posted: 02:39pm 19 Apr 2012
  TassyJim said   Just a small update to MM Edit.
That is an excellent idea!
