I was wondering if anyone has powered a USB device and interacted with it with the Duinomite. I am working on a datalogger and I am almost there but for one thing....I need to have the 5v,D+/D- out to USB. I vaguely remember or imagined that I needed some sort of jumper to use the OTG function. I am working with STICKOS for this project and it can log data to a USB Stick very fast I am told. I am sampling 6 ADC ports at 4 kHz each port which has amazed me! The timer functions are pretty cool although I find myself missing DMBASIC/MMBASIC sometimes...really miss the GOTO!
Any ideas?
Olimex Senior Member Joined: 02/10/2011 Location: BulgariaPosts: 226
Posted: 03:14pm 15 Apr 2012
no need for jumpers but your firmware should have USB host functionality implemented
indeed having BASIC with no GOTO seems to me quite weird too :)
Does the duinomite firmware support this feature? Do I need to update the firmware? How do I know if I need to update it?
I am so close to using this as a solution and at this point it would be great as the write speeds for USG Hosting on this chip are very very fast!
I have the mega and the mini....
I guess when you mean firmware you mean DMBASIC or STICKOS. I am running STICKOS. I like a it a lot by the way. Love the .25 millisecond counters. Very useful. According to the website it supports the feature USB Host mode for the PIC32MX795 microcontroller.
Edited by robarino 2012-04-17
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4391
Posted: 04:10pm 17 Apr 2012
If StickOS supports that, then it should work. Try it :)
