Local Time 01:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : suggestions about CGMMSTICK1
f1fco
Posted: 08:37am 14 Apr 2012
hello to all,
my english is very bad... (I use a translator word to word)
suggestions about the CGMMSTICK1 :
>the pin 4 is not connected, I use it for audio output (I link it with a short wire to audio out J5)
why not in a new design of the board ?
>the CGMMSTICK1 look like the SIMMSTICK (http://www.simmstick.com/whatissi.htm)
in a future design, is it possible to add a "pad" of copper near the 30 pins of J1
to connect the board on a 30 pin SIMM socket ?
73s from F1FCO (hamradio), Nimes, south of France
73s de F1FCO
CircuitGizmos
Posted: 04:56pm 14 Apr 2012
The board would have to be made thinner and would also need to be rearranged slightly to be a Simmstick. Plus it would need to be notched.
The board wasn't meant for SIMM sockets, but was meant for solderless breadboards. It may have followed some of the spirit of the Simmstick, but it was not meant to be one.
You can make it in to one with an adapter.Edited by CircuitGizmos 2012-04-16
f1fco
Posted: 07:37pm 14 Apr 2012
ok Glenn, no problem
it was just a suggestion
and for audio output on pin 4 of J1 ?
F1FCO, Pierre
73s de F1FCO
CircuitGizmos
Posted: 07:01pm 15 Apr 2012
  f1fco said   ok Glenn, no problem
F1FCO, Pierre
I'm not Glenn. If there is a redesign of the CGMMSTICK1, then the audio may be worth considering.
