Local Time 01:11 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Nokia 3110 LCD
jman
Posted: 07:47am 12 Apr 2012
Hi
I was playing with a Nokia 5110 LCD and SPI
These displays are graphic with 84x48 Pixels
So we need to create our own fonts in software(But the displays are real cheap)
Ebay 5110 LCD
Code attached
2012-04-12_174610_NLCDv1.zip
Posted: 02:27am 13 Apr 2012
  jman said   Hi
Great Work John,
Can you post the hardware connections as well?
ArtBecker
Posted: 03:56am 13 Apr 2012
You will find literally over 1.5 million Google search engine hits for "Nokia 3310 display."
The 3310 is the same as the 3315 (and the 3310 itself can be flashed to a 3315).
The local cell phone parts center still sells the 3310 etc. display and keyboard assembly for about $2.50 -- the keyboard section can be cut off.
The display has its contacts printed on glass, so you need to use pressure to make a connection, if you don't have some kind of assembly.
The device will run at 5V but that can shorten its life. 3.3v is the preferred voltage.
There are conflicting online versions of the pinouts (but not the actual display), so you need to make sure you are using the right pins.
Chapter 4 of the book TinyAVR Projects for the Evil Genius is a nice guide to using this display, and I have seen it mentioned in other publications. There is even a photo of the assembly I mentioned above, on page 104.
MakerShed in the USA sells a comparable kit for $10: MakerShed 5110 Display Kit
The eBay listing above is so cheap that buying at least a half dozen of these displays is a great idea, just on general principles.
You can create your own fonts, or use the display for graphics.
jman
Posted: 06:20am 13 Apr 2012
Sure
The LCd is wired as follows
Maximite Pin Nokia LCD
Pin 1 = Pin3(SCE)
Pin 2 SPI TX = Pin6(DN/MOSI)
Pin 3 SPI CLK = Pin7(SCLK)
Pin 4 = Pin4(RST)
Pin 5 = Pin5(D\C)
Pin 6 SPI RX Unused
Attached is an improved version with all the DATA statements removed
The fonts now load from the SD Card.
To use copy the included fonts.dat to your B: Drive
This has made the program memory use much better 9% VS 27%
2012-04-13_161903_NLCDv2.zip
