Local Time 01:11 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mmbasic 3.1 on maximite
plasma
Posted: 11:06pm 11 Apr 2012
hi ,
2 questions please
1.
for r = 1 to 9999
cls
next
- shows me [2J[H in the upper lefts corner
2. if i press f1 in the editor the code isnt saved on the sd
screen clear and show the cursor on upper left cursor ?
maximite using is fun .
shoebuckle
Posted: 11:46pm 11 Apr 2012
Item 1 happens for me too (although I don't see a use for such a routine).
[Quote]2. if i press f1 in the editor the code isnt saved on the sd
[/Quote]
F1 in the Editor doesn't save to the SD card, only to working memory. To save to SD card you must exit the Editor (F1) and SAVE "filename" at the prompt.
Cheers,
Hugh
plasma
Posted: 04:03am 12 Apr 2012
thx shoebuckle
@cls routine : ok not usefull ,but maybe a bug or ?
BobDevries
Posted: 04:45am 12 Apr 2012
Plasma (and all),
the code sequence <ESC>[2J is the ANSI code for CLEAR SCREEN
The code sequence <ESC>H is the ANSI code for HOME CURSOR.
My guess is that your terminal programme (PuTTY, TeraTerm, HyperTerminal) is not set to show ANSI codes.
Bob Devries
Dalby, QLD, Australia
paceman
Posted: 12:06pm 12 Apr 2012
Plasma,
You can also edit a file direct from the B: drive and save it back there with the F1 key, e.g.
type: edit "autorun.bas"
........do your editing.......
press: F1
...the edited file is saved straight to the SD card.
As per the MM manual:
EDIT - Invoke the full screen editor. This can be used to edit either the program
currently loaded in memory or a file on either drive A: or B:. It can also be
used to view and edit text data files.
If EDIT is used on its own it will edit the program memory. If 'filename' is
supplied the file will be edited leaving the program memory untouched.
