Local Time 01:05 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Failure Rate?
elchucko
Posted: 03:57am 27 Mar 2012
Has your MM ever failed? Seems mine has become unstable after being powered off for 3 months. Using Tera Term the MM only displays the cursor. On occasion it will display the "Geoff banner" after loading Tera Term but it takes a few seconds before it does display. I can type in program instructions which do execute i.e.,print "a", etc. I can't display any programs loaded to the sd card. I can't load any program. Ideas? Thank you.
P.S.
Seems like there has been some changes to the support of the MM. Any new forums that cover the subject?
BobD
Posted: 05:06am 27 Mar 2012
Check your 3.3 volts and read the forum guidelines for this section. Read Me. Guidelines for this section. See the section down the bottom for other support forums.
Posted: 06:31am 27 Mar 2012
  elchucko said   Has your MM ever failed? Seems mine has become unstable after being powered off for 3 months. Using Tera Term the MM only displays the cursor. On occasion it will display the "Geoff banner" after loading Tera Term but it takes a few seconds before it does display. I can type in program instructions which do execute i.e.,print "a", etc. I can't display any programs loaded to the sd card. I can't load any program. Ideas? Thank you.
Hi El Chuck,
Try it on either composite video or VGA with a PS2 keyboard , if it works fine it s likely to be USB related, if the same it may be a dry joint around the pic cpu ..
I seem to remember that you have the SM1 variety, have you added the extra cap across the power supply caps, not sure off hand which ones but you need to put a 22 uf cap across the smt caps that are conncted to the pic chip. Information is in this forum some where if you think that might be the case.
elchucko
Posted: 02:06am 28 Mar 2012
Soldered sd card connector and all is well.
