Local Time 01:05 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : More 3D ?.
Raros
Posted: 09:56am 17 Mar 2012
Hi
Has anyone experimented with 3D?
After this post (MM-DM-UBW32) The 3D Mite ! nobody has talked about more.
I sought information on the net and I took these new routines more compact and readable.
1) 4 points floating in space.
Variant 1
Rotating Square.
Variant 2
Rotating square with X the center.
' 4 Point in the space - 3D
pts = 4
Dim c(360),s(360)
Dim x(pts),y(pts),z(pts)
Dim x2(pts),y2(pts),z2(pts)
Dim x3(pts),y3(pts)
Dim xOld(pts),yOld(pts)
'cos and sin values stored for quick access
For i = 0 To 360
c(i) = Cos(i * 3.14 / 180)
s(i) = Sin(i * 3.14 / 180)
Next
'starting angles to which the object rotates
t = 360
p = 360
d = 360
'screen starting values
xc = 160
yc = 100
zc = 50
'add your own coordinates here
x(1)= 10
x(2)= 10
x(3)= -10
x(4)= -10
y(1)= 10
y(2)= -10
y(3)= 10
y(4)= -10
z(1)= 0
z(2)= 0
z(3)= 0
z(4)= 0
Cls
a$=Inkey$
a = c(p) * c(d)
b = c(p) * s(d)
L = (s(p) * s(t) * c(d) - c(t) * s(d))
de = (s(p) * s(t) * s(d) + c(t) * c(d))
e = c(p) * s(t)
f = (s(p) * c(t) * c(d) + s(t) * s(d))
g = (s(p) * c(t) * s(d) - s(d) * c(d))
h = c(p) * c(t)
For i = 1 To pts
x2(i) = x(i) * a + y(i) * b - z(i) * s(p)
y2(i) = x(i) * L + y(i) * de + z(i) * e
z2(i) = x(i) * f + y(i) * g + z(i) * h
x3(i) = 256 * (x2(i) / (z2(i) + zc)) + xc
y3(i) = 256 * (y2(i) / (z2(i) + zc)) + yc
' START VARIANT
' erase old point
Pixel(xOld(i), yOld(i))=0
' draw new point
Pixel(x3(i), y3(i))=1
' store this point
xOld(i)=x3(i):yOld(i)=y3(i)
Next
' END VARIANT
'increments the angles by one
p = p + 1
t = t + 1
d = d + 1
'if angle >360 then it is set to be below this won't
'work for negative angles
p = p Mod 360
t = t Mod 360
d = d Mod 360
Pause 30
'exit the program when the ESC key is pressed
Loop Until a$=Chr$(27)
End
' END PRG
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
' VARIANT 1
Next
' erase old line
Line (xOld(1),yOld(1))-(xOld(2),yOld(2)),0
Line (xOld(2),yOld(2))-(xOld(4),yOld(4)),0
Line (xOld(4),yOld(4))-(xOld(3),yOld(3)),0
Line (xOld(3),yOld(3))-(xOld(1),yOld(1)),0
' store vertices
For i = 1 To pts
Next
' draw new line
Line (x3(1),y3(1))-(x3(2),y3(2)),1
Line (x3(2),y3(2))-(x3(4),y3(4)),1
Line (x3(4),y3(4))-(x3(3),y3(3)),1
Line (x3(3),y3(3))-(x3(1),y3(1)),1
' XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
' VARIANT 2
Next
' erase old line
' erase old X
Line (xOld(1),yOld(1))-(xOld(4),yOld(4)),0
Line (xOld(2),yOld(2))-(xOld(3),yOld(3)),0
' store vertices
For i = 1 To pts
Next
' draw new line
' draw X
Line (x3(1),y3(1))-(x3(4),y3(4)),1
Line (x3(2),y3(2))-(x3(3),y3(3)),1
2) Cube 3D to rotate manually:
Up Arrow > zoom in.
Down Arrow > zoom out.
key 2 > Rotate Down.
key 8 > Rotate Up.
key 4 > Rotate Left.
key 6 > Rotate Right.
key 0 > Rotate Counterclockwise.
key . > Rotate Clockwise.
key ESC or SPACE > exit.
' Rotation cube manual
CLS
an = 5
sc = 1
fov = 45
n = 8
h = 2 / TAN(pi * fov / 360)
DIM a(n, 2)
DIM b(n, 3)
DIM c(n, 4)
cubes
an2 = an * pi / 180
mono
END
SUB cubel
LINE (a(1, 1), a(1, 2))-(a(4, 1), a(4, 2))
LINE (a(1, 1), a(1, 2))-(a(2, 1), a(2, 2))
LINE (a(1, 1), a(1, 2))-(a(5, 1), a(5, 2))
LINE (a(7, 1), a(7, 2))-(a(3, 1), a(3, 2))
LINE (a(7, 1), a(7, 2))-(a(6, 1), a(6, 2))
LINE (a(7, 1), a(7, 2))-(a(8, 1), a(8, 2))
LINE (a(2, 1), a(2, 2))-(a(3, 1), a(3, 2))
LINE (a(3, 1), a(3, 2))-(a(4, 1), a(4, 2))
LINE (a(4, 1), a(4, 2))-(a(8, 1), a(8, 2))
LINE (a(8, 1), a(8, 2))-(a(5, 1), a(5, 2))
LINE (a(5, 1), a(5, 2))-(a(6, 1), a(6, 2))
LINE (a(6, 1), a(6, 2))-(a(2, 1), a(2, 2))
END SUB
SUB cubes
c(1, 1) = 1
c(1, 2) = 1
c(1, 3) = 1
c(2, 1) = -1
c(2, 2) = 1
c(2, 3) = 1
c(3, 1) = -1
c(3, 2) = -1
c(3, 3) = 1
c(4, 1) = 1
c(4, 2) = -1
c(4, 3) = 1
c(5, 1) = 1
c(5, 2) = 1
c(5, 3) = -1
c(6, 1) = -1
c(6, 2) = 1
c(6, 3) = -1
c(7, 1) = -1
c(7, 2) = -1
c(7, 3) = -1
c(8, 1) = 1
c(8, 2) = -1
c(8, 3) = -1
FOR l = 1 TO n
c(l, 4) = 0
NEXT l
END SUB
SUB fov1
FOR l = 1 TO n
no = 0
x = (h - c(l, 3))
IF x > -.1 AND x < .1 THEN
x = 1
no = 1
ENDIF
z = 60 * h / x
IF z < 0 THEN
z = 1
no = 1
ENDIF
a(l, 1) = c(l, 1) * z + 152
a(l, 2) = c(l, 2) * z + 108
IF no = 1 THEN
r = 10000 / (c(l, 1) ^ 2 + c(l, 2) ^ 2) ^ .5
a(l, 1) = c(l, 1) * r + 152
a(l, 2) = c(l, 2) * r + 108
ENDIF
NEXT l
END SUB
SUB ky
k$ = ""
DO WHILE k$ = ""
k$ = INKEY$
LOOP
k$ = RIGHT$(k$, 1)
END SUB
SUB mono
CLS
ma:
fov1
CLS
cubel
mky:
ky
IF k$ = CHR$(27) OR k$ = " " THEN GOTO mz
rot
GOTO ma
mz:
END SUB
SUB rot
if k$ = " " then goto rz
' key Up Arrow > zoom in
if k$ = CHR$(128) Or k$ = CHR$(160) THEN
FOR l = 1 TO n
c(l, 3) = c(l, 3) + .5
NEXT l
GOTO rz
' key Down Arrow > zoom out
if k$ = CHR$(129) Or k$ = CHR$(161) THEN
FOR l = 1 TO n
c(l, 3) = c(l, 3) - .5
NEXT l
GOTO rz
' key ESC > exit
if k$ = CHR$(27) then goto rz
' Rotate Down.
if k$ = "2" THEN
si = SIN(0 - an2)
co = COS(0 - an2)
yz
GOTO rz
' Rotate Up.
if k$ = "8" THEN
si = SIN(0 + an2)
co = COS(0 + an2)
yz
GOTO rz
' Rotate Left.
if k$ = "4" THEN
si = SIN(0 + an2)
co = COS(0 + an2)
xz
GOTO rz
' Rotate Right.
if k$ = "6" THEN
si = SIN(0 - an2)
co = COS(0 - an2)
xz
GOTO rz
' Rotate Counterclockwise.
if k$ = "0" THEN
si = SIN(0 - an2)
co = COS(0 - an2)
xy
GOTO rz
' Rotate Clockwise.
if k$ = "." THEN
si = SIN(0 + an2)
co = COS(0 + an2)
xy
GOTO rz
rz:
END SUB
SUB xy
FOR l = 1 TO n
x = c(l, 1)
y = c(l, 2)
c(l, 2) = y * co + x * si
c(l, 1) = x * co - y * si
NEXT l
END SUB
SUB xz
FOR l = 1 TO n
x = c(l, 1)
z = c(l, 3)
c(l, 3) = z * co + x * si
c(l, 1) = x * co - z * si
NEXT l
END SUB
SUB yz
FOR l = 1 TO n
y = c(l, 2)
z = c(l, 3)
c(l, 3) = z * co + y * si
c(l, 2) = y * co - z * si
NEXT l
END SUB
3) Rotating 3D Cube with 2 variations.
Variant 1
With an X.
Variant 2
With Double X.
' Cube 3D Rotation.
numLines = 11 ' 12 (0 to 11)
DIM lO(numLines,1,3) ' AS pnt 'Original line coords
DIM lR(numLines,1,3) ' AS pnt 'Rotated coords
DIM scrX(numLines,1) ' screen x coord
DIM scrY(numLines,1) ' screen y coord
DIM oldX(numLines,1) ' old x coord for erasing
DIM oldY(numLines,1) ' old y coord for erasing
DIM sj(359) ' trig tables
DIM cj(359)
x = 0
y = 1
Z = 2
p = 3
FOR i = 0 TO 359 ' create sine and cosine
sj(i) = SIN(i * (PI / 180)) ' look up tables to speed up
cj(i) = COS(i * (PI / 180)) ' the math
NEXT
' Read two points instead of one.
FOR i = 0 TO numLines
READ lO(i,0,x), lO(i,0,y), lO(i,0,z), lO(i,0,p)
READ lO(i,1,x), lO(i,1,y), lO(i,1,z), lO(i,1,p)
NEXT
CLS
xCenter = 160
yCenter = 100
zCenter = 256
theta = 0
phi = 0
thetaRot = 2
phiRot = 2
justStarted = 1
DO
' Save the old values of x and y so we can erase the balls later.
oldX(i,0) = scrX(i,0): oldY(i,0) = scrY(i,0)
oldX(i,1) = scrX(i,1): oldY(i,1) = scrY(i,1)
' Rotate both points on each axis.
lR(i,0,x) = -lO(i,0,x) * sj(theta) + lO(i,0,y) * cj(theta)
lR(i,0,y) = -lO(i,0,x) * cj(theta) * sj(phi) - lO(i,0,y) * sj(theta) * sj(phi) - lO(i,0,z) * cj(phi) + lO(i,0,p)
lR(i,0,z) = -lO(i,0,x) * cj(theta) * cj(phi) - lO(i,0,y) * sj(theta) * cj(phi) + lO(i,0,z) * sj(phi)
lR(i,1,x) = -lO(i,1,x) * sj(theta) + lO(i,1,y) * cj(theta)
lR(i,1,y) = -lO(i,1,x) * cj(theta) * sj(phi) - lO(i,1,y) * sj(theta) * sj(phi) - lO(i,1,z) * cj(phi) + lO(i,1,p)
lR(i,1,z) = -lO(i,1,x) * cj(theta) * cj(phi) - lO(i,1,y) * sj(theta) * cj(phi) + lO(i,1,z) * sj(phi)
' Translate both points from 3D to 2D.
IF (lR(i,0,z) + zCenter) <> 0 THEN
scrX(i,0) = 256 * (lR(i,0,x) / (lR(i,0,z) + zCenter)) + xCenter
scrY(i,0) = 256 * (lR(i,0,y) / (lR(i,0,z) + zCenter)) + yCenter
ENDIF
IF (lR(i,1,z) + zCenter) <> 0 THEN
scrX(i,1) = 256 * (lR(i,1,x) / (lR(i,1,z) + zCenter)) + xCenter
scrY(i,1) = 256 * (lR(i,1,y) / (lR(i,1,z) + zCenter)) + yCenter
ENDIF
NEXT i
Pause 20
IF justStarted = 0 THEN
' Erase old lines.
LINE (oldX(i,0), oldY(i,0))-(oldX(i,1), oldY(i,1)), 0
NEXT i
' START VARIANT
' Draw new lines.
LINE (scrX(i,0), scrY(i,0))-(scrX(i,1), scrY(i,1)), 1
NEXT i
' END VARIANT
theta = (theta + thetaRot) MOD 360
phi = (phi + phiRot) MOD 360
justStarted = 0
LOOP UNTIL INKEY$ = CHR$(27)
End
' Lines are stored in format (X1,Y1,Z1,p1)-(X2,Y2,Z2,p2)
DATA -50,50,50,1,50,50,50,1
DATA 50,-50,50,1,50,50,50,1
DATA 50,50,-50,1,50,50,50,1
DATA -50,-50,50,1,-50,50,50,1
DATA -50,50,-50,1,-50,50,50,1
DATA -50,-50,50,1,50,-50,50,1
DATA -50,50,-50,1,50,50,-50,1
DATA -50,-50,-50,1,50,-50,-50,1
DATA -50,-50,-50,1,-50,50,-50,1
DATA 50,-50,-50,1,50,-50,50,1
DATA 50,-50,-50,1,50,50,-50,1
DATA -50,-50,-50,1,-50,-50,50,1
' PRG END
'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
' VARIANT 1
' Erase old X.
LINE (oldX(9, 0), oldY(9, 0))-(oldX(5, 0), oldY(5, 0)), 0
LINE (oldX(1, 0), oldY(1, 0))-(oldX(8, 0), oldY(8, 0)), 0
' Draw new lines.
LINE (scrX(i, 0), scrY(i, 0))-(scrX(i, 1), scrY(i, 1)), 1
NEXT i
' Draw X.
LINE (scrX(9, 0), scrY(9, 0))-(scrX(5, 0), scrY(5, 0)), 1
LINE (scrX(1, 0), scrY(1, 0))-(scrX(8, 0), scrY(8, 0)), 1
' VARIANT 2
' Erase double X.
LINE (oldX(2, 0), oldY(2, 0))-(oldX(5, 0), oldY(5, 0)), 0
LINE (oldX(1, 0), oldY(1, 0))-(oldX(4, 0), oldY(4, 0)), 0
LINE (oldX(0, 0), oldY(0, 0))-(oldX(9, 0), oldY(9, 0)), 0
LINE (oldX(0, 1), oldY(0, 1))-(oldX(8, 0), oldY(8, 0)), 0
' Draw new lines.
NEXT i
' Draw double X.
LINE (scrX(2, 0), scrY(2, 0))-(scrX(5, 0), scrY(5, 0)), 1
LINE (scrX(1, 0), scrY(1, 0))-(scrX(4, 0), scrY(4, 0)), 1
LINE (scrX(0, 0), scrY(0, 0))-(scrX(9, 0), scrY(9, 0)), 1
LINE (scrX(0, 1), scrY(0, 1))-(scrX(8, 0), scrY(8, 0)), 1
All 2012-03-17_200112_3D_MMbas31.zip
I hope I can help someone.
Bye, Raros
Edited by Raros 2012-03-18
darthmite
Posted: 09:41pm 17 Mar 2012
Hi ,
I don't have develop the 3D more with this concept because it's a little too limited.
The best is to have some big array's and then get the 3D objects information from
a file in the SD card.
You will then be able to made allot more with the 3D algorithm.
But then it's possible to get allot memory for nothing because each variable in
the array get 4 bytes ....
A little RAM expansion will be welcome here
Cheer.
